[PATCH 08/26] leon, can: introduce common CAN baud-rate calculation function
Fri Oct 16 05:35:57 UTC 2020
Hello Daniel,
On 29/06/2020 14:27, Sebastian Huber wrote:
> On 29/06/2020 14:22, Daniel Hellstrom wrote:
>> On 2020-06-29 13:48, Sebastian Huber wrote:
>>> On 29/06/2020 13:27, Daniel Hellstrom wrote:
>>>> + *  COPYRIGHT (c) 2019.
>>>> + *  Cobham Gaisler AB.
>>>> + *  The license and distribution terms for this file may be
>>>> + *  found in the file LICENSE in this distribution or at
>>>> + *http://www.rtems.org/license/LICENSE.
>>> What are your plans with respect to the BSD-2-Clause relicensing? At
>>> least for new code it would be nice to use this license.
>> Ok, I based the text on the LICENSE.BSD-2-Clause in the root, please
>> check being my first time..
> Sorry, it looks like we have to update this file. The latest template is
> this one:
> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-assembler-source-file-template
what are your plans with respect to the new files. Do you intend to send
a second version with the standard header and the BSD-2-Clause license
or do you want to keep it as is? I would like to integrate this patch
set, since some users asked for it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
