[PATCH 08/26] leon, can: introduce common CAN baud-rate calculation function
daniel at gaisler.com
Fri Oct 16 13:04:10 UTC 2020
2020-10-16 07:35 skrev Sebastian Huber:
> Hello Daniel,
> On 29/06/2020 14:27, Sebastian Huber wrote:
>> On 29/06/2020 14:22, Daniel Hellstrom wrote:
>>> On 2020-06-29 13:48, Sebastian Huber wrote:
>>>> On 29/06/2020 13:27, Daniel Hellstrom wrote:
>>>>> + * COPYRIGHT (c) 2019.
>>>>> + * Cobham Gaisler AB.
>>>>> + * The license and distribution terms for this file may be
>>>>> + * found in the file LICENSE in this distribution or at
>>>>> + *http://www.rtems.org/license/LICENSE.
>>>> What are your plans with respect to the BSD-2-Clause relicensing? At
>>>> least for new code it would be nice to use this license.
>>> Ok, I based the text on the LICENSE.BSD-2-Clause in the root, please
>>> check being my first time..
>> Sorry, it looks like we have to update this file. The latest template
>> is this one:
>> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html#c-c-assembler-source-file-template
> what are your plans with respect to the new files. Do you intend to
> send a second version with the standard header and the BSD-2-Clause
> license or do you want to keep it as is? I would like to integrate
> this patch set, since some users asked for it.
I have sent an updated version with what I think is the correct BSD
header now. And I sent a separate patch updating the
LICENSE.BSD-2-Clause file to match the homepage. I hope I haven't missed
anything.
