set_vector() on SPARC
Sebastian Huber
Mon Oct 19 05:51:50 UTC 2020
On 16/10/2020 19:48, Joel Sherrill wrote:
> On Thu, Oct 15, 2020 at 11:40 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 16/10/20 3:30 pm, Sebastian Huber wrote:
> > On 16/10/2020 03:09, Chris Johns wrote:
> >> On 16/10/20 4:57 am, Sebastian Huber wrote:
> >>> I suggest to remove this function and replace it with
> rtems_interrupt_catch()
> >>> and add the interrupt enable to rtems_interrupt_catch().
> >> Which BSPs will this effect?
> > All SPARC BSPs.
> OK.
> Unless you make that all BSPs which have set_vector, I am not in favor
> of this.
> set_vector() was intended many many years ago as a central place for a
> BSP
> to touch an interrupt mask register if it had one. This was sometimes
> present
> on architectures which we now call simple vectored. This was universally
> present across all simple vectored architectures.
> If you want to eliminate it, do so. Don't leave it partially present.
My intention was to change this only on SPARC. The other architectures
that use set_vector() are not really maintained.
> >> What testing on real hardware will there be?
> > I will test on GR712RC and GR740. I hope Gaisler tests the RTEMS
> master from
> > time to time on their hardware.
> Yes. Testing as we are working on changes is much more helpful
> than finding out
> long after the focus has shifted.
> +1
Testing this change on everything except SPARC would be difficult.
