[PATCH v2] rtems-fdt / shell - Fix string truncation warning
Frank Kuehndel
frank.kuehndel at embedded-brains.de
Mon Oct 19 13:16:26 UTC 2020
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
The compiler warning was:
../../../cpukit/libmisc/rtems-fdt/rtems-fdt.c:267:5: warning:
'strncpy' specified bound depends on the length of the source argument
267 | strncpy(path, name, namelen);
It turns out that the `strncpy()` nor the buffer `path` is needed when
one uses `strncmp()` instead of `strcmp()`. This needs some change to
the algorithm but has the advantage that `name` is never truncated
to the size of the buffer `path`.
cpukit/libmisc/rtems-fdt/rtems-fdt.c | 40 +++++++++++++---------------
1 file changed, 19 insertions(+), 21 deletions(-)
diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt.c b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
index 39e70bffec..0ea365314f 100644
--- a/cpukit/libmisc/rtems-fdt/rtems-fdt.c
+++ b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
@@ -248,48 +248,46 @@ rtems_fdt_index_find_by_name(rtems_fdt_index* index,
int min = 0;
int max = index->num_entries;
- char path[256];
- const char* cmp_name = name;
* Handle trailing slash case.
- int namelen = strlen(name);
+ size_t namelen = strlen(name);
if (namelen > 0 && name[namelen-1] == '/')
namelen--;
- if (namelen >= (int)sizeof(path) - 1)
- namelen = sizeof(path) - 1;
- strncpy(path, name, namelen);
- path[namelen] = 0;
- cmp_name = path;
/* Binary search for the name. */
while (min < max)
int middle = (min + max) / 2;
- int cmp = strcmp(cmp_name, index->entries[middle].name);
+ int cmp = strncmp(name, index->entries[middle].name, namelen);
+ if (cmp == 0)
+ /* 'namelen' characters are equal but 'index->entries[middle].name' */
+ /* could have additional characters. */
+ if (index->entries[middle].name[namelen] == '\0')
+ /* Found it. */
+ return index->entries[middle].offset;
+ else
+ /* 'index->entries[middle].name' is longer than 'name'. */
+ cmp = -1;
if (cmp < 0)
/* Look lower than here. */
max = middle;
- else if (cmp > 0)
+ else
/* Look higher than here. */
min = middle + 1;
- else
- /* Found it. */
- return index->entries[middle].offset;
/* Didn't find it. */
return -FDT_ERR_NOTFOUND;
2.26.2
