[PATCH] libdebugger: Fix ARMv7-M with -O0
    Sebastian Huber
    Tue Oct 20 15:50:34 UTC 2020
On 02/04/2020 09:09, Sebastian Huber wrote:
> On 02/04/2020 08:46, Chris Johns wrote:
>> On 2020-04-02 16:53, Sebastian Huber wrote:
>>> Hallo Chris,
>>> On 21/03/2020 07:45, Sebastian Huber wrote:
>>>> On 20/03/2020 22:23, Chris Johns wrote:
>>>>>> On 20 Mar 2020, at 4:49 pm, Sebastian Huber
>>>>>> <sebastian.huber at embedded-brains.de> wrote:
>>>>>> On 20/03/2020 05:15, Chris Johns wrote:
>>>>>>> On 19/3/20 7:52 pm, Sebastian Huber wrote:
>>>>>>>> The ARMv7-M architecture has no CP-15.  The inline assembly for
>>>>>>>> the
>>>>>>>> CP-15 access leads to assembler errors if compiled with -O0.
>>>>>>> I would like to understand this one in detail to see why there
>>>>>>> is cp15 in the build.
>>>>>> In ARMv7-M the system registers are memory mapped.
>>>>>> If I compile a Cortex-M based BSP with -O0, then I get:
>>>>> BSP?
>>>> For example the atsamv BSP.
>>> could you please have a look at this. Being able to build with -O0
>>> is quite helpful during BSP development.
>> Is this important for 5.1.0?
> It is not absolutely necessary, but I regularly had to fix this
> locally. We have several ARMv7-M based BSPs. This was my first attempt
> to address this issue:
> https://lists.rtems.org/pipermail/devel/2019-February/024914.html
We work no on another Cortex-M based BSP and building with -O0 would be
really nice.
