[PATCH v4 0/1] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Utkarsh Rai
utkarsh.rai60 at gmail.com
Wed Oct 21 03:28:23 UTC 2020
This patch has the tests for clock_nanosleep with the CLOCK_MONOTONIC option.
The psxtests/psxclocknanosleep01/.. tests for valid timeout values as well as
for the effect on timeout delay when REALTIME clock is modified(no effect).
The timing tests are the similar to that for the REALTIME option(yielding and
blocking).
Utkarsh Rai (1):
.../psxtests/psxclocknanosleep01.yml | 19 +++
spec/build/testsuites/psxtmtests/grp.yml | 4 +
.../psxtmtests/psxtmclocknanosleep04.yml | 19 +++
.../psxtmtests/psxtmclocknanosleep05.yml | 19 +++
.../psxtests/psxclocknanosleep01/init.c | 145 ++++++++++++++++++
.../psxclocknanosleep01.doc | 13 ++
.../psxclocknanosleep01.scn | 50 ++++++
.../psxtmtests/psxtmclocknanosleep04/init.c | 70 +++++++++
.../psxtmtests/psxtmclocknanosleep05/init.c | 116 ++++++++++++++
9 files changed, 455 insertions(+)
create mode 100644 spec/build/testsuites/psxtests/psxclocknanosleep01.yml
create mode 100644 spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml
create mode 100644 spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml
create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep04/init.c
create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep05/init.c
2.25.1
