[PATCH v4 1/1] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Utkarsh Rai
utkarsh.rai60 at gmail.com
Wed Oct 21 03:28:24 UTC 2020
.../psxtests/psxclocknanosleep01.yml | 19 +++
spec/build/testsuites/psxtmtests/grp.yml | 4 +
.../psxtmtests/psxtmclocknanosleep04.yml | 19 +++
.../psxtmtests/psxtmclocknanosleep05.yml | 19 +++
.../psxtests/psxclocknanosleep01/init.c | 145 ++++++++++++++++++
.../psxclocknanosleep01.doc | 13 ++
.../psxclocknanosleep01.scn | 50 ++++++
.../psxtmtests/psxtmclocknanosleep04/init.c | 70 +++++++++
.../psxtmtests/psxtmclocknanosleep05/init.c | 116 ++++++++++++++
9 files changed, 455 insertions(+)
create mode 100644 spec/build/testsuites/psxtests/psxclocknanosleep01.yml
create mode 100644 spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml
create mode 100644 spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml
create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep04/init.c
create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep05/init.c
diff --git a/spec/build/testsuites/psxtests/psxclocknanosleep01.yml b/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
new file mode 100644
index 0000000000..990e4a633c
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxclocknanosleep01.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 Utkarsh Rai(utkarsh.rai60 at gmail.com)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxclocknanosleep01/init.c
+stlib: []
+target: testsuites/psxtests/psxclocknanosleep01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/psxtmtests/grp.yml b/spec/build/testsuites/psxtmtests/grp.yml
index 2d4c5b2b97..409d1c45b7 100644
--- a/spec/build/testsuites/psxtmtests/grp.yml
+++ b/spec/build/testsuites/psxtmtests/grp.yml
@@ -31,6 +31,10 @@ links:
uid: psxtmclocknanosleep02
- role: build-dependency
uid: psxtmclocknanosleep03
+- role: build-dependency
+ uid: psxtmclocknanosleep04
+ uid: psxtmclocknanosleep05
uid: psxtmcond01
diff --git a/spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml b/spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml
index 0000000000..12672c79ed
--- /dev/null
+++ b/spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+- Copyright (C) 2020 Utkarsh Rai (utkarsh.rai60 at gmail.com)
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtmtests/psxtmclocknanosleep04/init.c
+stlib: []
+target: testsuites/psxtmtests/psxtmclocknanosleep04.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml b/spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml
index 0000000000..a3634341de
--- /dev/null
+++ b/spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml
@@ -0,0 +1,19 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtmtests/psxtmclocknanosleep05/init.c
+stlib: []
+target: testsuites/psxtmtests/psxtmclocknanosleep05.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/psxclocknanosleep01/init.c b/testsuites/psxtests/psxclocknanosleep01/init.c
index 0000000000..278683953c
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/init.c
@@ -0,0 +1,145 @@
+/* SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Utkarsh Rai
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <limits.h>
+#include <time.h>
+#include <rtems/test.h>
+#include <rtems/test-info.h>
+T_TEST_CASE( POSIXClock_Timeout_finite )
+ struct timespec delay_time;
+ int eno;
+ eno = clock_gettime( CLOCK_MONOTONIC, &delay_time );
+ T_eno_success( eno );
+ delay_time.tv_sec += 1;
+ eno = clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &delay_time, NULL );
+T_TEST_CASE( POSIXClock_Timeout_huge_nsec )
+ int eno;
+ delay_time.tv_sec = 1;
+ delay_time.tv_nsec = LONG_MAX;
+ T_eno( EINVAL, eno );
+T_TEST_CASE( POSIXClock_Timeout_negative_sec )
+ int eno;
+ delay_time.tv_sec = -1;
+ delay_time.tv_nsec = 1;
+T_TEST_CASE( POSIXClock_Timeout_negative_nsec )
+ int eno;
+ delay_time.tv_nsec = -1;
+T_TEST_CASE(POSIXClock_Timeout_negative_sec_nsec)
+ int eno;
+ T_eno( EINVAL, eno);
+T_TEST_CASE( POSIXClock_Timeout_clock_modify )
+ struct timespec configure_time;
+ int eno;
+ * Modify the REALTIME clock, this should not have any effect on the sleep time
+ * with the MONOTONIC clock.
+ eno = clock_gettime( CLOCK_REALTIME, &configure_time );
+ configure_time.tv_sec += 3600;
+ eno = clock_settime( CLOCK_REALTIME, &configure_time );
+const char rtems_test_name[] = "POSIXCLOCKNANOSLEEP01";
+static rtems_task Init ( rtems_task_argument argument )
+ rtems_test_run( argument, TEST_STATE );
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#include <rtems/confdefs.h>
\ No newline at end of file
diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
index 0000000000..803c2cff15
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
@@ -0,0 +1,13 @@
+This file describes the directives and concepts tested by this test set.
+test set name: psxclocknanosleep01
+directives:
+- clock_nanosleep()
+concepts:
+- Test some invalid and extreme timeout values.
+- Ensure that the CLOCK_MONOTONIC based delay is not affected by changes to
+ CLOCK_REALTIME
diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
index 0000000000..38479c27fd
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
@@ -0,0 +1,50 @@
+** BEGIN OF TEST POSIXCLOCKNANOSLEEP01 ***
+*** TEST VERSION: 6.0.0.560c08cc3d458cdeb4abc014deef8f4ce42a5d54
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD:
+*** TEST TOOLS: 10.2.1 20200918 (RTEMS 6, RSB ed5030bc24dbfdfac52074ed78cf4231bf1f353d, Newlib 749cbcc)
+A:POSIXCLOCKNANOSLEEP01
+S:Platform:RTEMS
+S:Compiler:10.2.1 20200918 (RTEMS 6, RSB ed5030bc24dbfdfac52074ed78cf4231bf1f353d, Newlib 749cbcc)
+S:Version:6.0.0.560c08cc3d458cdeb4abc014deef8f4ce42a5d54
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:0
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:0
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:0
+B:POSIXClock_Timeout_negative_sec_nsec
+P:0:0:UI1:init.c:99
+E:POSIXClock_Timeout_negative_sec_nsec:N:1:F:0:D:0.004953
+P:0:0:UI1:init.c:74
+E:POSIXClock_Timeout_negative_sec:N:1:F:0:D:0.000541
+B:POSIXClock_Timeout_negative_nsec
+P:0:0:UI1:init.c:87
+E:POSIXClock_Timeout_negative_nsec:N:1:F:0:D:0.000347
+B:POSIXClock_Timeout_huge_nsec
+P:0:0:UI1:init.c:62
+E:POSIXClock_Timeout_huge_nsec:N:1:F:0:D:0.000271
+B:POSIXClock_Timeout_finite
+P:0:0:UI1:init.c:43
+P:1:0:UI1:init.c:50
+E:POSIXClock_Timeout_finite:N:2:F:0:D:0.009012
+B:POSIXClock_Timeout_clock_modify
+P:0:0:UI1:init.c:109
+P:1:0:UI1:init.c:113
+P:2:0:UI1:init.c:116
+P:3:0:UI1:init.c:121
+E:POSIXClock_Timeout_clock_modify:N:4:F:0:D:1.008998
+Z:POSIXCLOCKNANOSLEEP01:C:6:N:10:F:0:D:1.027995
+Y:ReportHash:SHA256:7abe99f057e7ed39a7cd7ffd51c6ff0e0ec85ef1b8fe153399bd1b0a185bcfeb
+*** END OF TEST POSIXCLOCKNANOSLEEP01 ***
+*** FATAL ***
+fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
+fatal code: 0 (0x00000000)
+RTEMS version: 6.0.0.560c08cc3d458cdeb4abc014deef8f4ce42a5d54
+RTEMS tools: 10.2.1 20200918 (RTEMS 6, RSB ed5030bc24dbfdfac52074ed78cf4231bf1f353d, Newlib 749cbcc)
+executing thread ID: 0x08a010001
+executing thread name: UI1
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep04/init.c b/testsuites/psxtmtests/psxtmclocknanosleep04/init.c
index 0000000000..4dd83b3201
--- /dev/null
+++ b/testsuites/psxtmtests/psxtmclocknanosleep04/init.c
@@ -0,0 +1,70 @@
+ * are met:
+#endif
+#include <errno.h>
+#include <time.h>
+#include <timesys.h>
+#include <pthread.h>
+#include <rtems/btimer.h>
+const char rtems_test_name[] = "PSXTMCLOCKNANOSLEEP 04";
+T_TEST_CASE( POSIX_Clocknanosleep_monotonic_yield )
+ benchmark_timer_t end_time;
+ struct timespec sleep_time;
+ sleep_time.tv_sec = 0;
+ sleep_time.tv_nsec = 1;
+ benchmark_timer_initialize();
+ clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &sleep_time, NULL );
+ end_time = benchmark_timer_read();
+ put_time( "clock_nanosleep(MONOTONIC): yield", end_time, 1, 0, 0 );
+static rtems_task Init( rtems_task_argument argument)
+#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
diff --git a/testsuites/psxtmtests/psxtmclocknanosleep05/init.c b/testsuites/psxtmtests/psxtmclocknanosleep05/init.c
index 0000000000..dd43b4dc36
--- /dev/null
+++ b/testsuites/psxtmtests/psxtmclocknanosleep05/init.c
@@ -0,0 +1,116 @@
+ * are met:
+#endif
+#include <errno.h>
+#include <time.h>
+const char rtems_test_name[] = "PSXTMCLOCKNANOSLEEP 05";
+void *Low(
+ void *argument
+ put_time(
+ "clock_nanosleep(MONOTONIC): blocking",
+ end_time,
+ OPERATION_COUNT,
+ 0,
+ 0
+ return NULL;
+void *Middle(
+ void *argument
+ /* calling nanosleep */
+ struct timespec sleepTime;
+ sleepTime.tv_sec = 0;
+ sleepTime.tv_nsec = 1;
+ clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &sleepTime, NULL );
+ return NULL;
+T_TEST_CASE( POSIX_Clocknanosleep_monotonic_blocking )
+ int i;
+ int status;
+ pthread_t threadId;
+ struct timespec remainder;
+ remainder.tv_sec = 0;
+ remainder.tv_nsec = 0;
+ for ( i = 0 ; i < OPERATION_COUNT - 1 ; i++ ) {
+ status = pthread_create( &threadId, NULL, Middle, NULL );
+ T_psx_success( status );
+ status = pthread_create( &threadId, NULL, Low, NULL );
+ /* start the timer and switch through all the other tasks */
+ /* calling clock_nanosleep*/
+ clock_nanosleep( CLOCK_MONOTONIC, TIMER_ABSTIME, &sleepTime, &remainder );
+#define CONFIGURE_MAXIMUM_POSIX_THREADS OPERATION_COUNT + 1
2.25.1
