Fatal exceptions on context-switching for more than two isolated threads
Utkarsh Rai
utkarsh.rai60 at gmail.com
Fri Oct 23 16:58:43 UTC 2020
On Fri, Oct 23, 2020 at 9:57 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Oct 23, 2020 at 9:37 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
> wrote:
> > On Thu, Oct 22, 2020 at 11:23 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >> On 22/10/2020 02:40, Utkarsh Rai wrote:
> >> > Hello, this thread has gone a bit cold over the last few weeks, due to
> >> > my engagement in the university tests. I have provided a debug trace
> >> > for the issue. The reason for fatal exceptions is the fact that while
> >> > iterating over the chain of user extensions we access a node whose
> >> > memory location has been set to NO-ACCESS during the context switch.
> >> > Is there any work-around to this?
> >> The option is to move the User_extensions_Iterator storage out of the
> >> stack to Thread_Control and Per_CPU_Control.
> > Does this mean that I should add User_extensions_Iterator field in the
> Thread_Control structure for the case
> > when we enable thread stack protection?
> You need to dig in a little bit more. From what I understand, there is
> the last_user_extensions_iterator field of the TCB. That is probably
> where you are running into some trouble. See
> score/src/userextiterate.c :193 where this field gets assigned to a
> stack-local variable.
I get an exception just before this when _Chain_Iterator_initialize() is
called, the reason though is the same, accessing
a stack-local variable of a switched out thread. From what I could
understand, the 'iter' variable(corresponding to the
User_extensions_Iterator type)
is the only stack-local variable of a switched out thread that is accessed
from a different thread.
> Then, you can't walk this chain when the thread
> is out of context.
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201023/948c448d/attachment.html>
