AW: [PATCH 1/3] Remove duplicate GRETH driver
Jiri Gaisler
jiri at gaisler.se
Mon Oct 26 12:52:20 UTC 2020
On 10/26/20 3:37 AM, Gabriel.Moyano at dlr.de wrote:
> Hi Jiri,
> My understanding was that one driver version was meant to be used with drvmgr (greth.c) and the other without it (greth2.c). May I ask why do you've chosen to remove greth.c and not greth2.c?
The problem I had was that greth.c contains SPARC assembly code and
cannot be built on any other architecture. I will change my patch to
disable greth.c on non-SPARC targets or try to replace the asssembly
code with macros as in greth2.c. Thanks for the feedback!
An other issue is that the two files are 99% identical, but only greth,c
seems to be maintained. PHY handling and multi-cast support are areas
where the files have diverged. But this is an other discussion ...
> Thanks,
> Gabriel
> -----Ursprüngliche Nachricht-----
> Von: devel <devel-bounces at rtems.org> Im Auftrag von Jiri Gaisler
> Gesendet: Sonntag, 25. Oktober 2020 23:26
> An: devel at rtems.org
> Betreff: [PATCH 1/3] Remove duplicate GRETH driver
> * bsps/shared/net/greth2.c is being used instead
> bsps/shared/grlib-sources.am | 4 -
> bsps/shared/grlib/net/README | 7 -
> bsps/shared/grlib/net/greth.c | 1655 -----------------
> bsps/shared/grlib/net/network_interface_add.c | 62 -
> 4 files changed, 1728 deletions(-)
> delete mode 100644 bsps/shared/grlib/net/README
> delete mode 100644 bsps/shared/grlib/net/greth.c
> delete mode 100644 bsps/shared/grlib/net/network_interface_add.c
