AW: [PATCH 1/3] Remove duplicate GRETH driver
Jiri Gaisler
jiri at gaisler.se
Tue Oct 27 14:17:40 UTC 2020
On 10/26/20 8:52 AM, Jiri Gaisler wrote:
> On 10/26/20 3:37 AM, Gabriel.Moyano at dlr.de wrote:
>> Hi Jiri,
>> My understanding was that one driver version was meant to be used with drvmgr (greth.c) and the other without it (greth2.c). May I ask why do you've chosen to remove greth.c and not greth2.c?
I have fixed-up the greth.c file to avoid inline SPARC assembly code,
but the file is not used even when RTEMS is compiled with
--enable-drvmgr. The problem is that both greth2.c and greth.c are
compiled, and as they define the same symbols, greth2.c is pulled in
first by chance. I need to disable the building of the network files in
bsps/shared/shared-sources.am when --enable-drvmgr is defined. Does
anyone know how to do this? My skills in m4 etc. are limited ... :-(
> The problem I had was that greth.c contains SPARC assembly code and
> cannot be built on any other architecture. I will change my patch to
> disable greth.c on non-SPARC targets or try to replace the asssembly
> code with macros as in greth2.c. Thanks for the feedback!
> An other issue is that the two files are 99% identical, but only greth,c
> seems to be maintained. PHY handling and multi-cast support are areas
> where the files have diverged. But this is an other discussion ...
>> Thanks,
>> Gabriel
>> -----Ursprüngliche Nachricht-----
>> Von: devel <devel-bounces at rtems.org> Im Auftrag von Jiri Gaisler
>> Gesendet: Sonntag, 25. Oktober 2020 23:26
>> An: devel at rtems.org
>> Betreff: [PATCH 1/3] Remove duplicate GRETH driver
>> * bsps/shared/net/greth2.c is being used instead
>> bsps/shared/grlib-sources.am | 4 -
>> bsps/shared/grlib/net/README | 7 -
>> bsps/shared/grlib/net/greth.c | 1655 -----------------
>> bsps/shared/grlib/net/network_interface_add.c | 62 -
>> 4 files changed, 1728 deletions(-)
>> delete mode 100644 bsps/shared/grlib/net/README
>> delete mode 100644 bsps/shared/grlib/net/greth.c
>> delete mode 100644 bsps/shared/grlib/net/network_interface_add.c
> devel mailing list
> devel at rtems.org
