rtems-bsp-builder and rtems6 vs rtems7
Mon Oct 26 15:49:34 UTC 2020
Hi
I tried one of my build sweeps on rtems7 and there were some issues. First
the arm gcc didn't build but that is likely transient.  The
rtems-bsp-builder had a complete set of failures -- all 1696 because the
target used was rtems6.
https://lists.rtems.org/pipermail/build/2020-October/020269.html
/home/joel/rtems-cron-7/rtems/configure --target=arm-\
      rtems6 --enable-rtemsbsp=beagleboardxm --prefix=/home/joel/rtems-\
      cron-7/tools/7/bsps --enable-rtems-debug --enable-networking\
      --disable-smp
rtems-bsp-builder does not take target or version as an argument so it must
be generated internally. Is there a way to make it build for 7 instead of
defaulting to 6?
Also there is no way from the subject line in the build list archives to
tell 5 v 6 v 7.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201026/2aa8e052/attachment-0001.html>
