rtems-bsp-builder and rtems6 vs rtems7
Chris Johns
chrisj at rtems.org
Mon Oct 26 23:14:50 UTC 2020
On 27/10/20 2:49 am, Joel Sherrill wrote:
> Hi
> I tried one of my build sweeps on rtems7 and there were some issues. First the
> arm gcc didn't build but that is likely transient. The rtems-bsp-builder had a
> complete set of failures -- all 1696 because the target used was rtems6.
> https://lists.rtems.org/pipermail/build/2020-October/020269.html
> /home/joel/rtems-cron-7/rtems/configure --target=arm-\
> rtems6 --enable-rtemsbsp=beagleboardxm --prefix=/home/joel/rtems-\
> cron-7/tools/7/bsps --enable-rtems-debug --enable-networking\
> --disable-smp
> rtems-bsp-builder does not take target or version as an argument so it must be
> generated internally. Is there a way to make it build for 7 instead of
> defaulting to 6?
> Also there is no way from the subject line in the build list archives to tell 5
> v 6 v 7.
There is no option to set an RTEMS version. I could be added but I am not sure
how much work it would be.
