LibBSD PowerPC motorola_shared BSP PCI Support
Heinz Junkes
junkes at fhi-berlin.mpg.de
Tue Oct 27 14:23:17 UTC 2020
I am currently trying git rtems6.
../source-builder/sb-set-builder --prefix=$HOME/.rtems --log powerpc_beatnik.log --no-clean --target=powerpc-rtems6 --with-rtems-bsp=beatnik 6/rtems-powerpc 6/rtems-kernel
works …
Unfortunately It fails here:
../source-builder/sb-set-builder --prefix=$HOME/.rtems --log libbsd.log --no-clean --target=powerpc-rtems6 --with-rtems-bsp=beatnik --host=powerpc-rtems6 6/rtems-libbsd
[1562/1948] Compiling freebsd/sbin/nvmecontrol/ns.c
In file included from /home/ad/.rtems/lib/gcc/powerpc-rtems6/10.2.1/include/c++/cstdlib:75,
from /home/ad/.rtems/lib/gcc/powerpc-rtems6/10.2.1/include/c++/stdlib.h:36,
from ../../freebsd/sys/sys/libkern.h:216,
from ../../freebsd/sys/sys/systm.h:543,
from ../../freebsd/sys/sys/mbuf.h:42,
from ../../rtemsbsd/rtems/rtems-bsd-cxx.cc:48:
/home/ad/.rtems/powerpc-rtems6/include/stdlib.h:309:6: error: conflicting declaration of C function 'void qsort_r(void*, size_t, size_t, int (*)(const void*, const void*, void*
), void*)'
309 | void qsort_r (void *__base, size_t __nmemb, size_t __size, int (*_compar)(const void *, const void *, void *), void *__thunk);
In file included from ../../freebsd/sys/sys/systm.h:543,
../../freebsd/sys/sys/libkern.h:211:7: note: previous declaration 'void qsort_r(void*, size_t, size_t, void*, int (*)(void*, const void*, const void*))'
211 | void qsort_r(void *base, size_t nmemb, size_t size, void *thunk,
Waf: Leaving directory `/home/ad/RTEMS_DEV/rtems-source-builder/rtems/build/rtems-libbsd-d964a6703c705cc92fd053bcefc08bb3b6baa0e2-powerpc-rtems6-1/rtems-libbsd-d964a6703c705cc9
2fd053bcefc08bb3b6baa0e2/build/powerpc-rtems6-beatnik-default'
Build failed
-> task in 'bsd' failed with exit status 1 (run with -v to display more information)
shell cmd failed: /bin/sh -ex /home/ad/RTEMS_DEV/rtems-source-builder/rtems/build/rtems-libbsd-d964a6703c705cc92fd053bcefc08bb3b6baa0e2-powerpc-rtems6-1/do-build
error: building rtems-libbsd-d964a6703c705cc92fd053bcefc08bb3b6baa0e2-powerpc-rtems6-1
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 27. Oct 2020, at 05:06, Chris Johns <chrisj at rtems.org> wrote:
> On 26/10/20 7:32 pm, Heinz Junkes wrote:
>> Good morning Chris,
>> i will now try out libbsd on a MVME6100 (beatnik).
>> Is the mentioned patch in git?
> The PCI patch is in rtems-libbsd.git on the master and 6-freebsd-12 branches.
>> Or do I have to prepare something special?
> Yes I think you may need to patch libbsd for the beatnik bvoard. I have not
> looked at that board and the net drivers it needs. The current list is we have
> in libbsd is:
> https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h?h=6-freebsd-12
> The BSP support is handled here:
> https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/include/bsp/nexus-devices.h?h=6-freebsd-12
> The define is based on the header guard for the BSP:
> https://git.rtems.org/rtems/tree/bsps/powerpc/beatnik/include/bsp.h#n25
> I hope this helps.
> Chris
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201027/fae8af9b/attachment.bin>
