Change newlib daddr_t to 64 bits
Joel Sherrill
joel at rtems.org
Tue Oct 27 22:36:22 UTC 2020
On Tue, Oct 27, 2020 at 4:29 PM Chris Johns <chrisj at rtems.org> wrote:
> On 28/10/20 7:48 am, Joel Sherrill wrote:
> > On Tue, Oct 27, 2020, 3:44 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 28/10/20 7:14 am, Joel Sherrill wrote:
> > > Chris asked about a patch to newlib to make daddr_t 64-bits since
> it
> > represents
> > > a disk address. I haven't tested this because gcc master isn't
> building
> > for me.
> > > If this works Chris, I will post it to newlib.
> > The change works with the RTEMS 6 tools I have. I patched this file
> manually and
> > the effected code built.
> > Can the change be added to the RBS for the RTEMS 6 tools?
> > I can't get gcc master to build to verify this patch.
> I will try and patch RTEMS 6 tools using the BSP. Do we have a ticket for
> this
> issue? If not I can create one and then attach the patch.
We don't have an issue but I emailed the patch to newlib@ and since it
is RTEMS specific, I can push it after limited review.
Then we can just bump the newlib hash.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201027/e8fb1cfc/attachment.html>
