[PATCH 1/2] build: Report caching errors
Wed Oct 28 05:37:59 UTC 2020
The ctx.fatal() method uses an exception to stop the build.  Do not
catch it.
 wscript | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/wscript b/wscript
index ce71efc488..432d705107 100755
--- a/wscript
+++ b/wscript
@@ -1109,9 +1109,9 @@ def is_one_item_newer(ctx, path, mtime):
 def must_update_item_cache(ctx, path, cache_file):
     try:
         mtime = os.path.getmtime(cache_file)
-        return is_one_item_newer(ctx, path, mtime)
     except:
         return True
+    return is_one_item_newer(ctx, path, mtime)
 def load_from_yaml(load, ctx, data_by_uid, base, path):
2.26.2
