AW: [PATCH 1/3] Remove duplicate GRETH driver
Jiri Gaisler jiri at gaisler.se
Wed Oct 28 12:14:59 UTC 2020
On 10/28/20 2:44 AM, Jan.Sommer at dlr.de wrote:
>> -----Original Message-----
>> From: devel <devel-bounces at rtems.org> On Behalf Of Jiri Gaisler
>> Sent: Tuesday, October 27, 2020 3:18 PM
>> To: devel at rtems.org
>> Subject: Re: AW: [PATCH 1/3] Remove duplicate GRETH driver
>> On 10/26/20 8:52 AM, Jiri Gaisler wrote:
>>> On 10/26/20 3:37 AM, Gabriel.Moyano at dlr.de wrote:
>>>> Hi Jiri,
>>>> My understanding was that one driver version was meant to be used with
>> drvmgr (greth.c) and the other without it (greth2.c). May I ask why do you've
>> chosen to remove greth.c and not greth2.c?
>> I have fixed-up the greth.c file to avoid inline SPARC assembly code, but the
>> file is not used even when RTEMS is compiled with --enable-drvmgr. The
>> problem is that both greth2.c and greth.c are compiled, and as they define
>> the same symbols, greth2.c is pulled in first by chance. I need to disable the
>> building of the network files in bsps/shared/shared-sources.am when --
>> enable-drvmgr is defined. Does anyone know how to do this? My skills in m4
>> etc. are limited ... :-(
> If 99% of the code are the same, would it be an option to have just one driver implementation and in the drvmgr just use a wrapper for the driver?
This is my idea to, but the driver manager code is sprinkled out in the
file so it might take quite a few ifdefs to fix. In any case, I still
need to fix the m4 macros to detect if driver manager is defined or not ...
> Best regards,
>     Jan
>>> The problem I had was that greth.c contains SPARC assembly code and
>>> cannot be built on any other architecture. I will change my patch to
>>> disable greth.c on non-SPARC targets or try to replace the asssembly
>>> code with macros as in greth2.c. Thanks for the feedback!
>>> An other issue is that the two files are 99% identical, but only
>>> greth,c seems to be maintained. PHY handling and multi-cast support
>>> are areas where the files have diverged. But this is an other discussion ...
>>>> Thanks,
>>>> Gabriel
>>>> -----Ursprüngliche Nachricht-----
>>>> Von: devel <devel-bounces at rtems.org> Im Auftrag von Jiri Gaisler
>>>> Gesendet: Sonntag, 25. Oktober 2020 23:26
>>>> An: devel at rtems.org
>>>> Betreff: [PATCH 1/3] Remove duplicate GRETH driver
>>>> 	* bsps/shared/net/greth2.c is being used instead
>>>>  bsps/shared/grlib-sources.am                  |    4 -
>>>>  bsps/shared/grlib/net/README                  |    7 -
>>>>  bsps/shared/grlib/net/greth.c                 | 1655 -----------------
>>>>  bsps/shared/grlib/net/network_interface_add.c |   62 -
>>>>  4 files changed, 1728 deletions(-)
>>>>  delete mode 100644 bsps/shared/grlib/net/README  delete mode
>> 100644
>>>> bsps/shared/grlib/net/greth.c  delete mode 100644
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
