[PATCH v4 0/1] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Utkarsh Rai utkarsh.rai60 at gmail.com
Wed Oct 28 13:34:07 UTC 2020
Ping.
On Wed, Oct 21, 2020 at 8:58 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> This patch has the tests for clock_nanosleep with the CLOCK_MONOTONIC
> option.
> The psxtests/psxclocknanosleep01/.. tests for valid timeout values as well
> as
> for the effect on timeout delay when REALTIME clock is modified(no effect).
> The timing tests are the similar to that for the REALTIME option(yielding
> and
> blocking).
> Utkarsh Rai (1):
>  .../psxtests/psxclocknanosleep01.yml          |  19 +++
>  spec/build/testsuites/psxtmtests/grp.yml      |   4 +
>  .../psxtmtests/psxtmclocknanosleep04.yml      |  19 +++
>  .../psxtmtests/psxtmclocknanosleep05.yml      |  19 +++
>  .../psxtests/psxclocknanosleep01/init.c       | 145 ++++++++++++++++++
>  .../psxclocknanosleep01.doc                   |  13 ++
>  .../psxclocknanosleep01.scn                   |  50 ++++++
>  .../psxtmtests/psxtmclocknanosleep04/init.c   |  70 +++++++++
>  .../psxtmtests/psxtmclocknanosleep05/init.c   | 116 ++++++++++++++
>  9 files changed, 455 insertions(+)
>  create mode 100644 spec/build/testsuites/psxtests/psxclocknanosleep01.yml
>  create mode 100644
> spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml
>  create mode 100644
> spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml
>  create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
>  create mode 100644
> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
>  create mode 100644
> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
>  create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep04/init.c
>  create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep05/init.c
> 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201028/817d6687/attachment-0001.html>
