Error in RTEMS (Master)
Wed Sep 2 04:57:43 UTC 2020
On 02/09/2020 02:12, Joel Sherrill wrote:
> On Tue, Sep 1, 2020, 5:53 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 2/9/20 7:37 am, Eshan Dhawan wrote:
>      > Hello everyone,
>      > I was building rtems for arm-rtems6 using RSB(master) for BSP
>     xilinx_zynq_a9_qemu
>      > and received this error while making rtems.
>     I built the rtems.git master for this BSP the other day and it was
>     OK. I wonder
>     if ....
>     https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-kernel-6.cfg
>     ... needs to be updated to the HEAD on master for rtems.git?
> Sebastian posted about the on newlib. I think a patch was posted today
> to resolve this. Not sure if it is merged or not yet.
> Does make -k show other failures? It works let you ignore this issue.
Yes, a recent change in Newlib broke the arm and riscv libm.a.
We need some automated and continuous testing of the tool chain. I do
this currently manually from time to time (one to four weeks), but just
building the tools is apparently not enough. We also have to build the
BSPs with the tests and run the test suite on simulators. We support a
couple of targets that are not regularly tested by someone else, e.g. bfin.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
