Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Wed Sep 2 16:18:03 UTC 2020
On 02/09/2020 18:10, buildbot at rtems.org wrote:
> The Buildbot has detected a failed build on builder CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
> Full details are available at:
>      https://buildbot.rtems.org/#builders/20/builds/229
> Buildbot URL: https://buildbot.rtems.org/
> Worker for this Build: build-1
> Build Reason: <unknown>
> Blamelist: Sebastian Huber <sebastian.huber at embedded-brains.de>
> BUILD FAILED: make (failure)
> Sincerely,
>   -The Buildbot
This build error is due to a problem which is later fixed in the same
patch set. I think buildbot should just report this commit as failing
and then continue with the next commit in the patch series.
