Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Chris Johns
chrisj at rtems.org
Wed Sep 2 23:03:39 UTC 2020
On 3/9/20 2:18 am, Sebastian Huber wrote:
> On 02/09/2020 18:10, buildbot at rtems.org wrote:
>> The Buildbot has detected a failed build on builder CHECK sparc/erc32 FreeBSD
>> 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
>> Full details are available at:
>> https://buildbot.rtems.org/#builders/20/builds/229
>> Buildbot URL: https://buildbot.rtems.org/
>> Worker for this Build: build-1
>> Build Reason: <unknown>
>> Blamelist: Sebastian Huber <sebastian.huber at embedded-brains.de>
>> BUILD FAILED: make (failure)
>> Sincerely,
>> -The Buildbot
> This build error is due to a problem which is later fixed in the same patch set.
> I think buildbot should just report this commit as failing and then continue
> with the next commit in the patch series.
Please raise a ticket and assign it to Amar.
Thanks
