Error in RTEMS (Master)
Wed Sep 2 17:39:00 UTC 2020
On Wed, Sep 2, 2020 at 7:56 AM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Sep 1, 2020 at 11:57 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 02/09/2020 02:12, Joel Sherrill wrote:
>> > On Tue, Sep 1, 2020, 5:53 PM Chris Johns <chrisj at rtems.org
>> > <mailto:chrisj at rtems.org>> wrote:
>> >     On 2/9/20 7:37 am, Eshan Dhawan wrote:
>> >      > Hello everyone,
>> >      > I was building rtems for arm-rtems6 using RSB(master) for BSP
>> >     xilinx_zynq_a9_qemu
>> >      > and received this error while making rtems.
>> >     I built the rtems.git master for this BSP the other day and it was
>> >     OK. I wonder
>> >     if ....
>> https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-kernel-6.cfg
>> >     ... needs to be updated to the HEAD on master for rtems.git?
>> > Sebastian posted about the on newlib. I think a patch was posted today
>> > to resolve this. Not sure if it is merged or not yet.
>> > Does make -k show other failures? It works let you ignore this issue.
>> Yes, a recent change in Newlib broke the arm and riscv libm.a.
>> We need some automated and continuous testing of the tool chain. I do
>> this currently manually from time to time (one to four weeks), but just
>> building the tools is apparently not enough. We also have to build the
>> BSPs with the tests and run the test suite on simulators. We support a
>> couple of targets that are not regularly tested by someone else, e.g.
>> bfin.
> I was doing this regularly up until a couple of months ago. I need to
> switch
> my scripts over to 6 and modified them to also build from the 5 branch.
> It built all targets, all BSPs, and ran tests where a simulator was
> available.
> It took a long time to run on a fast machine. Multiple days on the slower
> machines running FreeBSD 12 and Ubuntu we have for testing.
> I will try to start running this more frequently.
FYI I started a full sweep on the faster Centos machine this morning and
results are popping out on build@ now.
--joel
> --joel
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200902/b485b359/attachment.html>
