Introducing the Strong APA Scheduler
Richi Dubey
richidubey at gmail.com
Thu Sep 3 15:10:00 UTC 2020
Hi,
Any views on this?
On Fri, Aug 28, 2020 at 7:42 PM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> I am happy to announce the release of the final version of the Strong APA
> scheduler.
> The documentation for the scheduler is live at
> https://richidubey.github.io/Strong-APA-Documentation/html/
> Improvements over the Pre-Release version
> <https://lists.rtems.org/pipermail/devel/2020-August/061560.html>:
> - Implemented changes for the reviews received on the 3 patches
> - Does not manipulate/access the variables of the Per CPU Control of any
> CPU
> The changes from the last patch of pre-release version can be seen here: Github
> Link
> <https://github.com/richidubey/rtems/pull/7/commits/e542a76befcb0c2a3f638c395eb6404932c00447>
> The changes from the current RTEMS state can be seen here: Github Link
> <https://github.com/richidubey/rtems/pull/8/files>
> Patch for the scheduler: Devel lists link
> <https://lists.rtems.org/pipermail/devel/2020-August/061661.html>
> The scheduler has only been tested on 1 test
> <https://lists.rtems.org/pipermail/devel/2020-August/061474.html> so far
> and I plan on adding more tests and testing this version on them in the
> next few days.
> Please let me know about your views and also if you think anything's still
> wrong in the code.
> Thanks,
> Richi.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200903/c89e71c8/attachment.html>
