dl06 fails to build for RISC-V (griscv bsp)
Jiri Gaisler jiri at gaisler.se
Mon Sep 7 08:01:19 UTC 2020
On 9/7/20 10:44 AM, Hesham Almatary wrote:
> I have only made sure rap builds when I added libdl support for
> RISC-V. But I haven't tested it on run-time, only ELF objects. It's
> likely to have been failing in run-time all along. Also, there are a
> few relocations still to be implemented for ELF like PCREL_LO12_X and
> RELAX. I got around that by passing -mno-relax
Very interesting! I applied -mno-relax when building dl06, and the error then changed to:
error: rap::object: Section index '0' not found: /home/jiri/src/rtems/6/bin/../lib/gcc/riscv-rtems6/10.2.1/../../../../riscv-rtems6/lib/rv32imafd/ilp32d/libm.a:lib_a-e_atan2.o at 709534
Does this indicate that newlib must be build with -mno-relax? If so, maybe we should disable the dlxx tests for RISC-V ..?
> On Sun, 6 Sep 2020 at 19:50, Jiri Gaisler <jiri at gaisler.se> wrote:
>> I re-applied your patch and dl06 builds again, but the dl06.exe program fails. I have updated the ticket:
>> https://devel.rtems.org/ticket/4069#no2
>> On 9/6/20 10:12 AM, Hesham Almatary wrote:
>>> That's the same as [1]. I've seen that error before and (thought I)
>>> fixed it [2], but not sure what has changed since then.
>>> [1] https://lists.rtems.org/pipermail/devel/2020-August/061717.html
>>> [2] https://github.com/RTEMS/rtems-tools/commit/e6e610d262940b7651157597b6b1406aa806b4d1
>>> On Sun, 6 Sep 2020 at 09:14, Chris Johns <chrisj at rtems.org> wrote:
>>>> On 6/9/20 6:32 am, Jiri Gaisler wrote:
>>>>> I have updated both RTEMS and RSB to git head, and dl06 now fails to build:
>>>>> riscv-rtems6-g++ -march=rv32imafd -mabi=ilp32d -O2 -g -ffunction-sections -fdata-sections -Wall      -Wl,--gc-sections  -march=rv32imafd -mabi=ilp32d  -B./../../lib/libbsp/riscv/griscv -B/home/jiri/ibm/src/rtems/rtems/bsps/riscv/griscv/start -specs bsp_specs -qrtems -L./../../cpukit -L/home/jiri/ibm/src/rtems/rtems/bsps/riscv/shared/start -Wl,--wrap=printf -Wl,--wrap=puts -Wl,--wrap=putchar -o dl05.exe dl05/dl05-init.o dl05/dl05-dl-load.o dl05/dl05-dl-cpp.o dl05-dl05-tar.o ../../lib/libbsp/riscv/griscv/librtemsbsp.a ../../cpukit/librtemscpu.a ../../cpukit/librtemstest.a dl05-sym.o
>>>> This is dl05 and I do not think it is related to the issue.
>>>>> rtems-ld -r /home/jiri/src/rtems/riscvmp/riscv-rtems6/c/griscv \
>>>>>   -C riscv-rtems6-gcc -c "-march=rv32imafd -mabi=ilp32d" \
>>>>>   -O rap -b dl06.pre -e rtems_main -s \
>>>>>   -o dl06.rap dl06-o1.o dl06-o2.o -lm
>>>>> error: rap::object: Section index '0' not found: dl06-o1.o
>>>>> Makefile:8528: recipe for target 'dl06.rap' failed
>>>>> make[5]: *** [dl06.rap] Error 10
>>>> This looks like something in rtems-ld in the rtems-tools.git repo.
>>>>> It seems like dl06-o1.o not built but a link is attempted - is dl06 supposed to be enabled or disabled for RISC-V ?
>>>> Enabled but it seems something has changed to cause the test to not link. I
>>>> wonder if a tool upgrade is the reason. I have raised ..
>>>> Chris
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
