We are loosing patches
Thomas Doerfler thomas.doerfler at embedded-brains.de
Wed Sep 9 15:04:48 UTC 2020
Hi Joe,
just a brief note from holidays:
Am 09.09.20 um 15:19 schrieb Joel Sherrill:
> All system administration on rtems.org <http://rtems.org> is volunteer.
> That by itself is the
> biggest barrier.
We've talked collecting funds through a foundation. How can we push that
to at least partly professionalize the administration?
IMHO we are stuck with "I want to do X when I find proper time for it".
Collecting (constant?) funds may solve this a bit. Other open source
projects made this move quite successfully.
wkr,
Thomas.
> --joel
>     Ph
>     Best regards,
>        Jan
>     > -----Original Message-----
>     > From: devel <devel-bounces at rtems.org
>     <mailto:devel-bounces at rtems.org>> On Behalf Of Christian Mauderer
>     > Sent: Wednesday, September 9, 2020 10:24 AM
>     > To: RTEMS Devel RTEMS <devel at rtems.org <mailto:devel at rtems.org>>
>     > Subject: We are loosing patches
>     > Hello,
>     > triggered by a comment from Chris here
>     >     https://lists.rtems.org/pipermail/users/2020-September/067873.html
>     > I started to take a look at patches from non maintainers and write
>     after
>     > approval maintainers for some months: I think in May and June we
>     lost at
>     > least one or two of the following ones:
>     > https://lists.rtems.org/pipermail/devel/2020-May/059751.html
>     > https://lists.rtems.org/pipermail/devel/2020-May/059771.html
>     > https://lists.rtems.org/pipermail/devel/2020-May/059772.html
>     > https://lists.rtems.org/pipermail/devel/2020-May/059773.html
>     > https://lists.rtems.org/pipermail/devel/2020-June/060125.html
>     > https://lists.rtems.org/pipermail/devel/2020-June/060231.html
>     > https://lists.rtems.org/pipermail/devel/2020-June/060235.html
>     > It's a bit hard to see exactly whether a later version has been
>     added with a
>     > different subject, merged with another patch or just has been
>     rejected for
>     > some reason. That's another problem with our current system.
>     > I think we start to loose valuable contributions due to that. I
>     also found some
>     > patches where just no one responded because no one noted it and the
>     > person sending the patch had to ping it some time later. That's
>     not really
>     > encouraging to continue participating for new contributors.
>     > I even lost track of some of my own patches in the past and found
>     out about
>     > a month later that I should have pushed them long ago.
>     > Maybe it would be a good idea to start at least discussing whether
>     we should
>     > change something to avoid these problems. I think our current
>     system has
>     > two main problems:
>     > 1. All patches go to one single devel mailing list. It's sometimes
>     hard to see
>     > which patches are for what repository. And small patches tend to
>     just vanish
>     > between lot of other mails.
>     > 2. We have a big problem seeing which patch sets are done, which
>     are in the
>     > middle of a discussion and which are rejected.
>     > A lot of other projects use software to solve these problems.
>     Linux uses
>     > "patchwork" for it since a long time (which needs one mailing list per
>     > project). Most other projects use systems with pull requests like
>     github or a
>     > self hosted gitlab for that kind of stuff.
>     > Maybe we should think about following these examples and go one
>     step to
>     > more modern software development too? What do you think?
>     > Best regards
>     > Christian
>     > embedded brains GmbH
>     > Herr Christian Mauderer
>     > Dornierstr. 4
>     > D-82178 Puchheim
>     > Germany
>     > email: christian.mauderer at embedded-brains.de
>     <mailto:christian.mauderer at embedded-brains.de>
>     > Phone: +49-89-18 94 741 - 18
>     > Fax:   +49-89-18 94 741 - 08
>     > PGP: Public key available on request.
>     > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>     > _______________________________________________
>     > devel mailing list
>     > http://lists.rtems.org/mailman/listinfo/devel
>     devel mailing list
> devel mailing list
> devel at rtems.org
Thomas Doerfler
Dornierstr. 4
D-82178 Puchheim
Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18 94 741-12
Fax:   +49-89-18 94 741-09
For our privacy statement, see
https://embedded-brains.de/en/data-privacy-statement/
