[PATCH 3/3] mcast01: Add test program
Thu Sep 10 07:51:44 UTC 2020
 libbsd.py                     |   1 +
 testsuite/mcast01/test_main.c | 285 ++++++++++++++++++++++++++++++++++
 2 files changed, 286 insertions(+)
 create mode 100644 testsuite/mcast01/test_main.c
diff --git a/libbsd.py b/libbsd.py
index 6a471873..c251fba4 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5141,6 +5141,7 @@ class tests(builder.Module):
         self.addTest(mm.generator['test']('media01', ['test_main'],
                                           runTest = False,
                                           extraLibs = ['ftpd', 'telnetd']))
+        self.addTest(mm.generator['test']('mcast01', ['test_main']))
         self.addTest(mm.generator['test']('vlan01', ['test_main'], netTest = True))
         self.addTest(mm.generator['test']('lagg01', ['test_main'], netTest = True))
         self.addTest(mm.generator['test']('log01', ['test_main']))
diff --git a/testsuite/mcast01/test_main.c b/testsuite/mcast01/test_main.c
new file mode 100644
index 00000000..60519719
--- /dev/null
+++ b/testsuite/mcast01/test_main.c
@@ -0,0 +1,285 @@
+ * @file
+ * @brief Example code to test multicasts.
+ * ping 224.0.0.1
+ * Linux:
+ * echo 0 > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts
+ * echo 1 > /proc/sys/net/ipv4/ip_forward
+ * ip route add 224.0.0.0/4 dev eth0
+ * echo "Hello, world!" > /dev/udp/239.1.2.3/1234
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#include <sys/param.h>
+#include <sys/socket.h>
+#include <sys/sysctl.h>
+#include <assert.h>
+#include <inttypes.h>
+#include <stdbool.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sysexits.h>
+#include <arpa/inet.h>
+#include <netinet/in.h>
+#include <machine/rtems-bsd-commands.h>
+#include <rtems/console.h>
+#include <rtems/shell.h>
+#include <rtems/dhcpcd.h>
+#define TEST_NAME "LIBBSD MCAST 1"
+#define TEST_STATE_USER_INPUT 1
+#define MCAST_PORT 1234
+#define MAX_PACKET_SIZE UINT16_MAX
+static const char mcast_addr[] = "239.1.2.3";
+static const char hello[] = "Hello, world!";
+typedef struct {
+	in_addr_t addr;
+	char name[];
+} iface_binding;
+static void
+set_mcast_route(const char *iface_name)
+	int exit_code;
+	char *route[] = {
+		"route",
+		"add",
+		"-net",
+		"224.0.0.0/4",
+		"-iface",
+		iface_name,
+		NULL
+	exit_code = rtems_bsd_command_route(RTEMS_BSD_ARGC(route), route);
+	assert(exit_code == EXIT_SUCCESS);
+static void
+mcast_rx_task(rtems_task_argument arg)
+	iface_binding *ifb;
+	struct ip_mreq mreq;
+	int sd;
+	struct sockaddr_in addr;
+	int rv;
+	char addr_buf[INET_ADDRSTRLEN];
+	const char *ip;
+	ssize_t n;
+	ifb = (iface_binding *)arg;
+	set_mcast_route(ifb->name);
+	memset(&addr, 0, sizeof(addr));
+	addr.sin_family = AF_INET;
+	addr.sin_addr.s_addr = ifb->addr;
+	ip = inet_ntop(AF_INET, &addr.sin_addr, addr_buf, sizeof(addr_buf));
+	printf("mcast: join %s using interface IP %s\n", mcast_addr, ip);
+	sd = socket(PF_INET,  SOCK_DGRAM, IPPROTO_UDP);
+	assert(sd >= 0);
+	addr.sin_port = htons(MCAST_PORT);
+	addr.sin_addr.s_addr = INADDR_ANY;
+	rv = bind(sd, (const struct sockaddr *)&addr, sizeof(addr));
+	assert(rv == 0);
+	memset(&mreq, 0, sizeof(mreq));
+	mreq.imr_multiaddr.s_addr = inet_addr(mcast_addr);
+	mreq.imr_interface.s_addr = ifb->addr;
+	rv = setsockopt(sd, IPPROTO_IP, IP_ADD_MEMBERSHIP, &mreq, sizeof(mreq));
+	assert(rv == 0);
+	addr.sin_addr.s_addr = inet_addr(mcast_addr);
+	n = sendto(sd, hello, sizeof(hello), 0,
+	    (const struct sockaddr *)&addr, sizeof(addr));
+	if (n != (ssize_t)sizeof(hello)) {
+		perror("send");
+	while (true) {
+		socklen_t addr_len;
+		char buf[MAX_PACKET_SIZE];
+		addr_len = sizeof(addr);
+		n = recvfrom(sd, buf, sizeof(buf), 0,
+		    (struct sockaddr *)&addr, &addr_len);
+		if (n >= 0 && addr.sin_addr.s_addr != ifb->addr) {
+			size_t m;
+			    sizeof(addr_buf));
+			printf("mcast: received %zi bytes from %s\n", n, ip);
+			m = (size_t)n;
+			n = sendto(sd, buf, m, 0,
+			    sizeof(addr));
+			assert(n == (ssize_t)m);
+		} else if (n < 0 ) {
+			perror("recvfrom");
+static void
+start_mcast_rx(const char *iface_ip, const char *iface_name)
+	rtems_status_code sc;
+	rtems_id id;
+	size_t len;
+	len = strlen(iface_name) + 1;
+	ifb = malloc(sizeof(*ifb) + len);
+	assert(ifb != NULL);
+	ifb->addr = inet_addr(iface_ip);
+	memcpy(ifb->name, iface_name, len);
+	sc = rtems_task_create(rtems_build_name('M', 'C', 'R', 'X'),
+	    RTEMS_MINIMUM_PRIORITY, RTEMS_MINIMUM_STACK_SIZE + MAX_PACKET_SIZE,
+	    RTEMS_DEFAULT_MODES, RTEMS_FLOATING_POINT, &id);
+	assert(sc == RTEMS_SUCCESSFUL);
+	sc = rtems_task_start(id, mcast_rx_task, (rtems_task_argument)ifb);
+static const char *
+get_value(char *const *env, const char *key)
+	size_t len;
+	len = strlen(key);
+	while (true) {
+		const char *s;
+		s = *env;
+		if (s == NULL) {
+			return "";
+		if (strncmp(key, s, len) == 0 && s[len] == '=') {
+			return &s[len + 1];
+		++env;
+static void
+dhcpcd_hook_handler(rtems_dhcpcd_hook *hook, char *const *env)
+	(void)hook;
+	if (strcmp(get_value(env, "reason"), "BOUND") == 0) {
+		start_mcast_rx(get_value(env, "new_ip_address"),
+		    get_value(env, "interface"));
+static rtems_dhcpcd_hook dhcpcd_hook = {
+	.name = "mcast",
+	.handler = dhcpcd_hook_handler
+static void
+test_main(void)
+	int enable;
+	int rv;
+	rtems_dhcpcd_add_hook(&dhcpcd_hook);
+	enable = 1;
+	rv = sysctlbyname("net.inet.icmp.bmcastecho", NULL, NULL, &enable,
+	    sizeof(enable));
+	assert(rv == 0);
+	sc = rtems_shell_init("SHLL", 16 * 1024, 1, CONSOLE_DEVICE_NAME,
+	    false, true, NULL);
+	exit(0);
+#define DEFAULT_NETWORK_DHCPCD_ENABLE
+#include <rtems/bsd/test/default-network-init.h>
+#define CONFIGURE_SHELL_COMMANDS_INIT
+#include <bsp/irq-info.h>
+#include <rtems/netcmds-config.h>
+#define CONFIGURE_SHELL_USER_COMMANDS \
+  &bsp_interrupt_shell_command, \
+  &rtems_shell_ARP_Command, \
+  &rtems_shell_HOSTNAME_Command, \
+  &rtems_shell_PING_Command, \
+  &rtems_shell_ROUTE_Command, \
+  &rtems_shell_NETSTAT_Command, \
+  &rtems_shell_SYSCTL_Command, \
+  &rtems_shell_IFCONFIG_Command, \
+  &rtems_shell_IFMCSTAT_Command, \
+  &rtems_shell_VMSTAT_Command
+#define CONFIGURE_SHELL_COMMAND_CPUINFO
+#define CONFIGURE_SHELL_COMMAND_CPUUSE
+#define CONFIGURE_SHELL_COMMAND_PERIODUSE
+#define CONFIGURE_SHELL_COMMAND_STACKUSE
+#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
+#include <rtems/shellconfig.h>
2.26.2
