[PATCH] CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
Sebastian Huber
Thu Sep 10 14:33:26 UTC 2020
Document this application configuration option.
Update #4074.
c-user/config/classic-api.rst | 35 +++++++++++++++++++++++++++++++++++
1 file changed, 35 insertions(+)
diff --git a/c-user/config/classic-api.rst b/c-user/config/classic-api.rst
index f0fbe6f..d7002ad 100644
--- a/c-user/config/classic-api.rst
+++ b/c-user/config/classic-api.rst
@@ -366,6 +366,41 @@ NOTES:
the addition of a new configuration parameter to specify the number of
tasks which enable floating point support.
+.. index:: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
+.. _CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE:
+CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE``
+OPTION TYPE:
+ This configuration option is an integer define.
+DEFAULT VALUE:
+ The default value is 0.
+VALUE CONSTRAINTS:
+ The value of this configuration option shall be greater than or equal to 0
+ and less than or equal to `SIZE_MAX <https://en.cppreference.com/w/c/types/limits>`_.
+DESCRIPTION:
+ If the value of this configuration option is greater than zero, then it
+ defines the maximum thread-local storage size, otherwise the thread-local
+ storage size is defined by the linker depending on the thread-local storage
+ objects used by the application in the statically-linked executable.
+NOTES:
+ This configuration option can be used to reserve space for the dynamic linking
+ of modules with thread-local storage objects.
+ If the thread-local storage size defined by the thread-local storage
+ objects used by the application in the statically-linked executable is greater
+ than a non-zero value of this configuration option, then a fatal error will
+ occur during system initialization.
.. index:: CONFIGURE_MAXIMUM_TIMERS
.. _CONFIGURE_MAXIMUM_TIMERS:
2.26.2
