[PATCH 0/3] libbsd: Add multicast test program
Thu Sep 10 11:33:17 UTC 2020
On 10/09/2020 12:38, Chris Johns wrote:
> On 10/9/20 8:17 pm, Sebastian Huber wrote:
>> On 10/09/2020 09:51, Sebastian Huber wrote:
>>> Sebastian Huber (3):
>>>     ifmcstat: Import from FreeBSD
>>>     ifmcstat: Port to RTEMS
>>>     mcast01: Add test program
>> I would like to back port this also to the 5-freebsd-12 branch. The ifmcstat
>> command is a helpful diagnostics command.
> I am fine with this. It will need a 5.2 ticket (I know you will do this).
> I have this command ported for the PTP work I am doing.
Thanks, I checked in the patches on 5-freebsd-12, 6-freebsd-12, and
master. For RTEMS 5.2 there is a ticket:
https://devel.rtems.org/ticket/4073
