[PATCH 0/3] libbsd: Add multicast test program
Joel Sherrill
joel at rtems.org
Thu Sep 10 12:57:13 UTC 2020
FWIW I have an mcast-writer and mcast-listener example that I got off the
net. I cleaned the warnings and changed it so it plugs in to the shell as a
user provided mains in the shell. I didn't know where it might belong to
even be a candidate to add. Here are the main files.
Not sure what to do with these.
On Thu, Sep 10, 2020 at 6:33 AM Sebastian Huber <
> On 10/09/2020 12:38, Chris Johns wrote:
> > On 10/9/20 8:17 pm, Sebastian Huber wrote:
> >> On 10/09/2020 09:51, Sebastian Huber wrote:
> >>> Sebastian Huber (3):
> >>> ifmcstat: Import from FreeBSD
> >>> ifmcstat: Port to RTEMS
> >>> mcast01: Add test program
> >> I would like to back port this also to the 5-freebsd-12 branch. The
> ifmcstat
> >> command is a helpful diagnostics command.
> > I am fine with this. It will need a 5.2 ticket (I know you will do this).
> > I have this command ported for the PTP work I am doing.
> Thanks, I checked in the patches on 5-freebsd-12, 6-freebsd-12, and
> master. For RTEMS 5.2 there is a ticket:
> https://devel.rtems.org/ticket/4073
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200910/752194c8/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200910/752194c8/attachment.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200910/752194c8/attachment-0001.obj>
