Introducing the Strong APA Scheduler
    Richi Dubey
    richidubey at gmail.com
    Thu Sep 10 18:55:57 UTC 2020
Yes.
You'll want to run a "clean" version also for comparison, to isolate
> problems you might introduce.
Shouldn't the clean version give no errors and timeouts? Cause mine does
give failures.
On Thu, Sep 10, 2020 at 9:02 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Sep 7, 2020 at 8:55 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Invalid directory. Sorry for the doubt.
> Did you get it working?
> > On Mon, Sep 7, 2020 at 8:18 PM Richi Dubey <richidubey at gmail.com> wrote:
> >>> You should run all tests that doesn't explicitly configure a scheduler
> >>> with your new implementation.
> >> I understand.
> >>> Maybey add an
> >>> #ifndef CONFIGURE_MAXIMUM_PROCESSORS
> >>> #define CONFIGURE_MAXIMUM_PROCESSORS 1
> >>> #endif
> >>> before the default scheduler selection.
> >> This works.
> >> I am getting this error:
> >> ./rtems-test \ --log=log_leon3_sis \ --rtems-bsp=leon3-sis \
> ~/quick-start/build/b-smp-leon3/sparc-rtems5/c/leon3/testsuites
> >> error: RTEMS Toolkit python wrapper not found, please report
> >> As far as I remember, I had done --enable-tests while building my bsp.
> >> On Mon, Sep 7, 2020 at 7:45 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> >>> On 07/09/2020 16:09, Richi Dubey wrote:
> >>> >     Did you
> >>> >     use rtems-test before?
> >>> > No. I'll do it now.
> >>> > I am individually testing each smp test for now on this patch:
> >>> >  cpukit/include/rtems/confdefs/scheduler.h | 2 +-
> >>> >  1 file changed, 1 insertion(+), 1 deletion(-)
> >>> > diff --git a/cpukit/include/rtems/confdefs/scheduler.h
> >>> > b/cpukit/include/rtems/confdefs/scheduler.h
> >>> > index 9305fc2d90..a93e765e53 100644
> >>> > --- a/cpukit/include/rtems/confdefs/scheduler.h
> >>> > +++ b/cpukit/include/rtems/confdefs/scheduler.h
> >>> > @@ -55,7 +55,7 @@
> >>> >    && !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
> >>> >    && !defined(CONFIGURE_SCHEDULER_USER)
> >>> >    #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
> >>> > -    #define CONFIGURE_SCHEDULER_EDF_SMP
> >>> > +    #define CONFIGURE_SCHEDULER_STRONG_APA
> >>> >    #else
> >>> >      #define CONFIGURE_SCHEDULER_PRIORITY
> >>> >    #endif
> >>> > because your suggested patch gives this error:
> >>> > In file included from
> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:64:0,
> >>> >                  from
> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/threads.h:48,
> >>> >                  from
> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/objectsposix.h:47,
> >>> >                  from
> >>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs.h:77,
> >>> >                  from
> /home/richi/quick-start/src/rtems/c/src/../../testsuites/samples/base_sp/system.h:39,
> >>> >                  from
> /home/richi/quick-start/src/rtems/c/src/../../testsuites/samples/base_sp/init.c:15:
> /home/richi/quick-start/src/rtems/cpukit/include/rtems/scheduler.h:260:37:
> >>> > error: 'CONFIGURE_MAXIMUM_PROCESSORS' undeclared here (not in a
> >>> > function); did you mean '_CONFIGURE_MAXIMUM_PROCESSORS'?
> >>> >        Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ];
> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:149:7:
> >>> > note: in expansion of macro 'RTEMS_SCHEDULER_STRONG_APA'
> >>> >        RTEMS_SCHEDULER_STRONG_APA( \
> /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:236:3:
> >>> > note: in expansion of macro 'CONFIGURE_SCHEDULER'
> >>> >    CONFIGURE_SCHEDULER;
> >>> > Makefile:939: recipe for target 'base_sp/base_sp-init.o'
> >>> > failedp-init.o' failed
> >>> > This is because single processor scheduler doesn't
> >>> > have CONFIGURE_MAXIMUM_PROCESSORS defined, So, would you like for me
> >>> > to make separate definition of CONFIGURE_SCHEDULER_STRONG_APA in
> >>> > cpukit/include/rtems/scheduler.h for a single processor system or
> does
> >>> > the current version that'd work only for SMP processor serve the
> purpose?
> >>> Maybey add an
> >>> #endif
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200911/f865407c/attachment.html>
