Introducing the Strong APA Scheduler
Gedare Bloom
gedare at rtems.org
Thu Sep 10 21:57:43 UTC 2020
On Thu, Sep 10, 2020 at 12:56 PM Richi Dubey <richidubey at gmail.com> wrote:
> Yes.
>> You'll want to run a "clean" version also for comparison, to isolate
>> problems you might introduce.
> Shouldn't the clean version give no errors and timeouts? Cause mine does give failures.
There are sometimes bugs or things we know that are broken. So you
need to know the baseline state.
> On Thu, Sep 10, 2020 at 9:02 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Sep 7, 2020 at 8:55 AM Richi Dubey <richidubey at gmail.com> wrote:
>> > Invalid directory. Sorry for the doubt.
>> Did you get it working?
>> > On Mon, Sep 7, 2020 at 8:18 PM Richi Dubey <richidubey at gmail.com> wrote:
>> >>> You should run all tests that doesn't explicitly configure a scheduler
>> >>> with your new implementation.
>> >> I understand.
>> >>> Maybey add an
>> >>> #ifndef CONFIGURE_MAXIMUM_PROCESSORS
>> >>> #define CONFIGURE_MAXIMUM_PROCESSORS 1
>> >>> #endif
>> >>> before the default scheduler selection.
>> >> This works.
>> >> I am getting this error:
>> >> ./rtems-test \ --log=log_leon3_sis \ --rtems-bsp=leon3-sis \ ~/quick-start/build/b-smp-leon3/sparc-rtems5/c/leon3/testsuites
>> >> error: RTEMS Toolkit python wrapper not found, please report
>> >> As far as I remember, I had done --enable-tests while building my bsp.
>> >> On Mon, Sep 7, 2020 at 7:45 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> >>> On 07/09/2020 16:09, Richi Dubey wrote:
>> >>> > Did you
>> >>> > use rtems-test before?
>> >>> > No. I'll do it now.
>> >>> > I am individually testing each smp test for now on this patch:
>> >>> > cpukit/include/rtems/confdefs/scheduler.h | 2 +-
>> >>> > 1 file changed, 1 insertion(+), 1 deletion(-)
>> >>> > diff --git a/cpukit/include/rtems/confdefs/scheduler.h
>> >>> > b/cpukit/include/rtems/confdefs/scheduler.h
>> >>> > index 9305fc2d90..a93e765e53 100644
>> >>> > --- a/cpukit/include/rtems/confdefs/scheduler.h
>> >>> > +++ b/cpukit/include/rtems/confdefs/scheduler.h
>> >>> > @@ -55,7 +55,7 @@
>> >>> > && !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
>> >>> > && !defined(CONFIGURE_SCHEDULER_USER)
>> >>> > #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
>> >>> > - #define CONFIGURE_SCHEDULER_EDF_SMP
>> >>> > + #define CONFIGURE_SCHEDULER_STRONG_APA
>> >>> > #else
>> >>> > #define CONFIGURE_SCHEDULER_PRIORITY
>> >>> > #endif
>> >>> > because your suggested patch gives this error:
>> >>> > In file included from
>> >>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:64:0,
>> >>> > from
>> >>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/threads.h:48,
>> >>> > from
>> >>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/objectsposix.h:47,
>> >>> > from
>> >>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs.h:77,
>> >>> > from
>> >>> > /home/richi/quick-start/src/rtems/c/src/../../testsuites/samples/base_sp/system.h:39,
>> >>> > from
>> >>> > /home/richi/quick-start/src/rtems/c/src/../../testsuites/samples/base_sp/init.c:15:
>> >>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/scheduler.h:260:37:
>> >>> > error: 'CONFIGURE_MAXIMUM_PROCESSORS' undeclared here (not in a
>> >>> > function); did you mean '_CONFIGURE_MAXIMUM_PROCESSORS'?
>> >>> > Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
>> >>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:149:7:
>> >>> > note: in expansion of macro 'RTEMS_SCHEDULER_STRONG_APA'
>> >>> > RTEMS_SCHEDULER_STRONG_APA( \
>> >>> > /home/richi/quick-start/src/rtems/cpukit/include/rtems/confdefs/scheduler.h:236:3:
>> >>> > note: in expansion of macro 'CONFIGURE_SCHEDULER'
>> >>> > CONFIGURE_SCHEDULER;
>> >>> > Makefile:939: recipe for target 'base_sp/base_sp-init.o'
>> >>> > failedp-init.o' failed
>> >>> > This is because single processor scheduler doesn't
>> >>> > have CONFIGURE_MAXIMUM_PROCESSORS defined, So, would you like for me
>> >>> > to make separate definition of CONFIGURE_SCHEDULER_STRONG_APA in
>> >>> > cpukit/include/rtems/scheduler.h for a single processor system or does
>> >>> > the current version that'd work only for SMP processor serve the purpose?
>> >>> Maybey add an
>> >>> #endif
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
