[PATCH 0/3] libbsd: Add multicast test program
Thu Sep 10 22:27:51 UTC 2020
On 10/9/20 9:33 pm, Sebastian Huber wrote:
> On 10/09/2020 12:38, Chris Johns wrote:
>> On 10/9/20 8:17 pm, Sebastian Huber wrote:
>>> On 10/09/2020 09:51, Sebastian Huber wrote:
>>>> Sebastian Huber (3):
>>>>     ifmcstat: Import from FreeBSD
>>>>     ifmcstat: Port to RTEMS
>>>>     mcast01: Add test program
>>> I would like to back port this also to the 5-freebsd-12 branch. The ifmcstat
>>> command is a helpful diagnostics command.
>> I am fine with this. It will need a 5.2 ticket (I know you will do this).
>> I have this command ported for the PTP work I am doing.
> Thanks, I checked in the patches on 5-freebsd-12, 6-freebsd-12, and master.
What about the 5 (master) branch which will be renamed to 5-freebsd-master?
> For RTEMS 5.2 there is a ticket:
> https://devel.rtems.org/ticket/4073
Thanks
