rtems_task_create_from_config() Name?
Mon Sep 14 04:52:28 UTC 2020
On 14/09/2020 00:30, Chris Johns wrote:
> On 14/9/20 12:11 am, Sebastian Huber wrote:
>> Hello Joel,
>> On 12/09/2020 05:38, Joel Sherrill wrote:
>>> Hi
>>> Starting another thread just to discuss this method's name. I wonder if the
>>> config part is more important than the static allocation of resources part.
>>> Which should be emphasized in the name?
>>>  From config puts focus on the attributes part. With static resources or
>>> similar puts emphasis on the other part.
>>> With config is more general but is there another mode of operation? Seems the
>>> static nature is more important and the name should.emohasize that.
>> I don't really like the name rtems_task_create_from_config(). The key feature of
>> this directive is that a user-provided thread storage area is used instead of a
>> system-provided. That the parameters for this new directive are contained in a
>> configuration structure is just an API choice. We could also use a function with
>> nine parameters.
>> I also don't like the wording "static" in this context. What we need is a
>> directive name for "create an Classic API task with a user-provided thread
>> storage area".
> rtems_task_create_with_storage()
> rtems_task_create_with_managed_storage()
Tasks always have a storage. It is always managed, the question is by whom?
> rtems_task_create_user_storage()
> rtems_task_create_user_managed_storage()
> rtems_task_create_user_provided_storage()
What does it create, a task or a user storage?
> They are created using the words from your sentence above :)
>> My favorite is still rtems_task_build().
> Not mine. Do you create, build then start? I think it needs create and it lacks
> the storage bit.
Maybe we should use a synonym of "create" (build is not a synonym of
create) such as "make":
rtems_task_make()
rtems_message_queue_make()
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
