rtems_task_create_from_config() Name?
Chris Johns
chrisj at rtems.org
Sun Sep 13 22:30:00 UTC 2020
On 14/9/20 12:11 am, Sebastian Huber wrote:
> Hello Joel,
> On 12/09/2020 05:38, Joel Sherrill wrote:
>> Hi
>> Starting another thread just to discuss this method's name. I wonder if the
>> config part is more important than the static allocation of resources part.
>> Which should be emphasized in the name?
>> From config puts focus on the attributes part. With static resources or
>> similar puts emphasis on the other part.
>> With config is more general but is there another mode of operation? Seems the
>> static nature is more important and the name should.emohasize that.
> I don't really like the name rtems_task_create_from_config(). The key feature of
> this directive is that a user-provided thread storage area is used instead of a
> system-provided. That the parameters for this new directive are contained in a
> configuration structure is just an API choice. We could also use a function with
> nine parameters.
> I also don't like the wording "static" in this context. What we need is a
> directive name for "create an Classic API task with a user-provided thread
> storage area".
rtems_task_create_with_storage()
rtems_task_create_with_managed_storage()
rtems_task_create_user_storage()
rtems_task_create_user_managed_storage()
rtems_task_create_user_provided_storage()
They are created using the words from your sentence above :)
> My favorite is still rtems_task_build().
Not mine. Do you create, build then start? I think it needs create and it lacks
the storage bit.
