[rtems commit] build: Add RELOCADDR to i386/pc386 options
Sebastian Huber
Wed Sep 16 06:25:18 UTC 2020
On 16/09/2020 01:26, Chris Johns wrote:
>> +default: 1048576
> Is hex supported? 0x100000 is much friendlier and simpler to grep for.
It would be difficult to add support for this. The YAML parser can read
hex number, however, the default YAML formatter writes all integers as
decimals. If you want hex numbers, then you need a hand crafted formatter.
In ./waf bsp_defaults you get a hex number (see the format attribute).
