[PATCH v5 6/7] validation: Add general purpose test suite
Wed Sep 16 14:49:09 UTC 2020
Add a general purpose test suite for validation tests.
This is the first test suite generated from a specification item in the
rtems-central repository.
Update #3959.
 Doxyfile                                      |   2 +-
 cpukit/doxygen/top-level-groups.h             |   6 +
 spec/build/testsuites/grp.yml                 |   4 +
 spec/build/testsuites/optvalidation.yml       |  15 ++
 spec/build/testsuites/validation/grp.yml      |  18 ++
 .../testsuites/validation/validation-0.yml    |  19 ++
 testsuites/validation/ts-validation-0.c       | 222 ++++++++++++++++++
 7 files changed, 285 insertions(+), 1 deletion(-)
 create mode 100644 spec/build/testsuites/optvalidation.yml
 create mode 100644 spec/build/testsuites/validation/grp.yml
 create mode 100644 spec/build/testsuites/validation/validation-0.yml
 create mode 100644 testsuites/validation/ts-validation-0.c
diff --git a/Doxyfile b/Doxyfile
index c794938191..ffb87fe89d 100644
--- a/Doxyfile
+++ b/Doxyfile
@@ -812,7 +812,7 @@ WARN_LOGFILE           =
 # spaces. See also FILE_PATTERNS and EXTENSION_MAPPING
 # Note: If this tag is empty the current directory is searched.
-INPUT                  = bsps cpukit
+INPUT                  = bsps cpukit testsuites/validation
 # This tag can be used to specify the character encoding of the source files
 # that doxygen parses. Internally doxygen uses the UTF-8 encoding. Doxygen uses
diff --git a/cpukit/doxygen/top-level-groups.h b/cpukit/doxygen/top-level-groups.h
index a177e8a715..c1a91a3482 100644
--- a/cpukit/doxygen/top-level-groups.h
+++ b/cpukit/doxygen/top-level-groups.h
@@ -42,3 +42,9 @@
  * @brief RTEMS Implementation.
+ * @defgroup RTEMSTestSuites Test Suites
+ * @brief Collection of Test Suites
diff --git a/spec/build/testsuites/grp.yml b/spec/build/testsuites/grp.yml
index ec2b6c616b..5c6457f06d 100644
--- a/spec/build/testsuites/grp.yml
+++ b/spec/build/testsuites/grp.yml
@@ -34,6 +34,8 @@ links:
   uid: optsp
 - role: build-dependency
   uid: opttm
+- role: build-dependency
+  uid: optvalidation
   uid: ada/grp
@@ -58,6 +60,8 @@ links:
   uid: sptests/grp
   uid: tmtests/grp
+  uid: validation/grp
 type: build
 use-after:
 - rtemscpu
diff --git a/spec/build/testsuites/optvalidation.yml b/spec/build/testsuites/optvalidation.yml
new file mode 100644
index 0000000000..81eb320d53
--- /dev/null
+++ b/spec/build/testsuites/optvalidation.yml
@@ -0,0 +1,15 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-boolean: null
+- env-enable: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+default: false
+default-by-variant: []
+description: |
+  Build the validation test programs (may be also enabled by BUILD_TESTS)
+enabled-by: true
+links: []
+name: BUILD_VALIDATIONTESTS
+type: build
diff --git a/spec/build/testsuites/validation/grp.yml b/spec/build/testsuites/validation/grp.yml
index 0000000000..390fb48803
--- /dev/null
+++ b/spec/build/testsuites/validation/grp.yml
@@ -0,0 +1,18 @@
+build-type: group
+copyrights:
+enabled-by:
+- BUILD_TESTS
+- BUILD_VALIDATIONTESTS
+includes:
+- ${BSP_INCLUDES}
+install: []
+ldflags: []
+links:
+  uid: validation-0
+type: build
+use-after:
+- rtemstest
+use-before: []
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index 0000000000..d024efb96f
--- /dev/null
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -0,0 +1,19 @@
+build-type: test-program
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/validation/ts-validation-0.c
+stlib: []
+target: testsuites/validation/ts-validation-0.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
index 0000000000..3e60fb6ab8
--- /dev/null
+++ b/testsuites/validation/ts-validation-0.c
@@ -0,0 +1,222 @@
+ * @file
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file was automatically generated.  Do not edit it manually.
+ * Please have a look at
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+ * for information how to maintain and re-generate this file.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/sysinit.h>
+#include <rtems/test.h>
+ * @defgroup RTEMSTestSuiteTestsuitesValidation0 spec:/testsuites/validation-0
+ * @ingroup RTEMSTestSuites
+ * @brief This general purpose validation test suite provides enough resources
+ *   to run basic tests for all specified managers and functions.
+ * In SMP configurations, up to three scheduler instances using the SMP EDF
+ * scheduler are provided using up to four processors.
+#include <rtems/test-info.h>
+const char rtems_test_name[] = "Validation0";
+static char buffer[ 512 ];
+static const T_action actions[] = {
+  T_report_hash_sha256,
+  T_check_task_context,
+  T_check_rtems_barriers,
+  T_check_rtems_extensions,
+  T_check_rtems_message_queues,
+  T_check_rtems_partitions,
+  T_check_rtems_periods,
+  T_check_rtems_semaphores,
+  T_check_rtems_tasks,
+  T_check_rtems_timers
+static const T_config test_config = {
+  .name = rtems_test_name,
+  .buf = buffer,
+  .buf_size = sizeof( buffer ),
+  .putchar = rtems_put_char,
+  .verbosity = T_VERBOSE,
+  .now = T_now_clock,
+  .action_count = T_ARRAY_SIZE( actions ),
+  .actions = actions
+static void runner_task( rtems_task_argument arg )
+  int exit_code;
+  (void) arg;
+  rtems_test_begin( rtems_test_name, TEST_STATE );
+  T_register();
+  exit_code = T_main( &test_config );
+  if ( exit_code == 0 ) {
+    rtems_test_end( rtems_test_name );
+  rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, (uint32_t) exit_code );
+#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
+#define ATTRIBUTES RTEMS_FLOATING_POINT
+RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
+static char runner_task_storage[
+  RTEMS_TASK_STORAGE_SIZE(
+    MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE,
+    ATTRIBUTES
+static const rtems_task_config runner_task_config = {
+  .name = rtems_build_name( 'R', 'U', 'N', ' ' ),
+  .initial_priority = 1,
+  .storage_area = runner_task_storage,
+  .storage_size = sizeof( runner_task_storage ),
+  .maximum_thread_local_storage_size = MAX_TLS_SIZE,
+  .initial_modes = RTEMS_DEFAULT_MODES,
+  .attributes = ATTRIBUTES
+static void init_runner_task(void)
+  rtems_id id;
+  rtems_status_code sc;
+  sc = rtems_task_construct( &runner_task_config, &id );
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, 1 );
+  sc = rtems_task_start( id, runner_task, 0 );
+RTEMS_SYSINIT_ITEM(
+  init_runner_task,
+  RTEMS_SYSINIT_CLASSIC_USER_TASKS,
+  RTEMS_SYSINIT_ORDER_MIDDLE
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_PROCESSORS 4
+#define CONFIGURE_MAXIMUM_BARRIERS 3
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 3
+#define CONFIGURE_MAXIMUM_PARTITIONS 3
+#define CONFIGURE_MAXIMUM_PERIODS 3
+#define CONFIGURE_MAXIMUM_SEMAPHORES 3
+#define CONFIGURE_MAXIMUM_TASKS 3
+#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE \
+  CONFIGURE_MAXIMUM_TASKS
+#define CONFIGURE_MAXIMUM_TIMERS 3
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 3
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+#define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body
+#if defined(RTEMS_SMP)
+#define CONFIGURE_SCHEDULER_EDF_SMP
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_EDF_SMP(a);
+RTEMS_SCHEDULER_EDF_SMP(b);
+RTEMS_SCHEDULER_EDF_SMP(c);
+#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
+  RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+  RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
+  RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+  RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+#endif /* RTEMS_SMP */
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
2.26.2
