devel Digest, Vol 106, Issue 81
Utkarsh Rai
utkarsh.rai60 at gmail.com
Wed Sep 16 15:38:00 UTC 2020
On Mon, Sep 14, 2020 at 5:30 PM <devel-request at rtems.org> wrote:
> Send devel mailing list submissions to
> devel at rtems.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> devel-owner at rtems.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of devel digest..."
> Today's Topics:
> 1. New build system ready for testing (Sebastian Huber)
> Message: 1
> Date: Mon, 14 Sep 2020 09:07:42 +0200
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> To: RTEMS <devel at rtems.org>
> Subject: New build system ready for testing
> Message-ID: <7530cecd-e1b4-b1be-af12-7593fc4566aa at embedded-brains.de>
> Content-Type: text/plain; charset=utf-8; format=flowed
> Hello,
> I checked in the new build system today. Now is a good time to test your
> favourite BSP if it still works.
Hello Sebastian, I have tested the new build system for the realview and
the xilinx_zynq_qemu BSP during my GSoC project. The config.ini file had
the options generated from "./waf bsp_defaults". The legacy stack for both
the BSPs builds successfully, the RSB build is also successful. Although I
am not sure how to run all the tests?
> You find the user oriented
> documentation of build system here:
> https://docs.rtems.org/branches/master/user/bld/index.html
> The documentation for RTEMS maintainers is here:
> https://docs.rtems.org/branches/master/eng/build-system.html
> How to check the new build system for a particular BSP?
> 1. Build the BSP with all tests enabled.
> 2. Run the tests and compare the results with the old build system.
> Ideally use the RTEMS Tester to run the tests and report them to the
> RTEMS Project.
> 3. Check if all BSP options are available (./waf bsp_defaults). Check
> the type and values of the BSP options.
> 4. Check the linker command file.
> 5. Check the compiler machine flags.
> 6. Install the BSP and build your third-party libraries and applications
> with it.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> Diese Nachricht ist keine gesch?ftliche Mitteilung im Sinne des EHUG.
> Subject: Digest Footer
> devel mailing list
> devel at rtems.org
> End of devel Digest, Vol 106, Issue 81
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200916/e12c5a4c/attachment.html>
