[PATCH v5 3/7] CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
Sebastian Huber
Wed Sep 16 14:49:06 UTC 2020
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
cpukit/doxygen/appl-config.h | 38 ++++++++++++++
cpukit/include/rtems/confdefs/threads.h | 7 +++
cpukit/include/rtems/rtems/tasks.h | 9 ++++
cpukit/include/rtems/score/interr.h | 3 +-
cpukit/include/rtems/score/thread.h | 10 ++++
cpukit/sapi/src/interrtext.c | 5 +-
cpukit/score/src/tlsallocsize.c | 16 ++++--
spec/build/testsuites/sptests/grp.yml | 2 +
spec/build/testsuites/sptests/spfatal33.yml | 19 +++++++
testsuites/sptests/spfatal33/init.c | 55 +++++++++++++++++++++
testsuites/sptests/spfatal33/spfatal33.doc | 11 +++++
testsuites/sptests/spfatal33/spfatal33.scn | 16 ++++++
testsuites/sptests/spinternalerror02/init.c | 4 +-
13 files changed, 187 insertions(+), 8 deletions(-)
create mode 100644 spec/build/testsuites/sptests/spfatal33.yml
create mode 100644 testsuites/sptests/spfatal33/init.c
create mode 100644 testsuites/sptests/spfatal33/spfatal33.doc
create mode 100644 testsuites/sptests/spfatal33/spfatal33.scn
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index cd4664f7c8..9593d9848d 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -801,6 +801,44 @@
#define CONFIGURE_MAXIMUM_TASKS
+ * @brief This configuration option is an integer define.
+ * If the value of this configuration option is greater than zero, then it
+ * defines the maximum thread-local storage size, otherwise the thread-local
+ * storage size is defined by the linker depending on the thread-local storage
+ * objects used by the application in the statically-linked executable.
+ * @par Default Value
+ * The default value is 0.
+ * @par Value Constraints
+ * The value of this configuration option shall be greater than or equal to 0
+ * and less than or equal to <a
+ * href="https://en.cppreference.com/w/c/types/limits">SIZE_MAX</a>.
+ * @par Notes
+ * @parblock
+ * This configuration option can be used to reserve space for the dynamic
+ * linking of modules with thread-local storage objects.
+ * If the thread-local storage size defined by the thread-local storage objects
+ * used by the application in the statically-linked executable is greater than
+ * a non-zero value of this configuration option, then a fatal error will occur
+ * during system initialization.
+ * Use RTEMS_ALIGN_UP() and #RTEMS_TASK_STORAGE_ALIGNMENT to adjust the size to
+ * meet the minimum alignment requirement of a thread-local storage area.
+ * @endparblock
+ * The actual thread-local storage size is determined when the application
+ * executable is linked. The ``rtems-exeinfo`` command line tool included in
+ * the RTEMS Tools can be used to obtain the thread-local storage size and
+ * alignment of an application executable.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
diff --git a/cpukit/include/rtems/confdefs/threads.h b/cpukit/include/rtems/confdefs/threads.h
index 33b8c5cee2..9e34696e61 100644
--- a/cpukit/include/rtems/confdefs/threads.h
+++ b/cpukit/include/rtems/confdefs/threads.h
@@ -84,6 +84,10 @@
#define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE THREAD_DEFAULT_MAXIMUM_NAME_SIZE
#endif
+#ifndef CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
+ #define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE 0
+#endif
#ifdef __cplusplus
extern "C" {
#endif
@@ -125,6 +129,9 @@ typedef union {
const size_t _Thread_Maximum_name_size = CONFIGURE_MAXIMUM_THREAD_NAME_SIZE;
+const size_t _Thread_Maximum_TLS_size =
+ CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE;
struct Thread_Configured_control {
Thread_Control Control;
#if CONFIGURE_MAXIMUM_USER_EXTENSIONS > 0
diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
index 12c323e60e..e07db6cd2b 100644
--- a/cpukit/include/rtems/rtems/tasks.h
+++ b/cpukit/include/rtems/rtems/tasks.h
@@ -164,6 +164,15 @@ rtems_status_code rtems_task_create(
rtems_id *id
+ * @brief This constant defines the recommended alignment of a task storage
+ * area in bytes.
+ * Use it with RTEMS_ALIGNED() to define the alignment of a statically
+ * allocated task storage area.
+#define RTEMS_TASK_STORAGE_ALIGNMENT CPU_HEAP_ALIGNMENT
* @brief RTEMS Task Name to Id
diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
index 2f449deedb..1371e55653 100644
--- a/cpukit/include/rtems/score/interr.h
+++ b/cpukit/include/rtems/score/interr.h
@@ -203,7 +203,8 @@ typedef enum {
INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED = 37,
INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT = 38,
INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL = 39,
- INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA = 40
+ INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA = 40,
+ INTERNAL_ERROR_TOO_LARGE_TLS_SIZE = 41
} Internal_errors_Core_list;
typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 1daf6143f9..1388744548 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -953,6 +953,16 @@ extern const size_t _Thread_Initial_thread_count;
extern const size_t _Thread_Maximum_name_size;
+ * @brief If this constant is greater than zero, then it defines the maximum
+ * thread-local storage size, otherwise the thread-local storage size is defined
+ * by the linker depending on the thread-local storage objects used by the
+ * application in the statically-linked executable.
+ * This value is provided via <rtems/confdefs.h>.
+extern const size_t _Thread_Maximum_TLS_size;
* @brief The configured thread control block.
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 2aff34487a..3d49135c44 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -7,7 +7,7 @@
- * Copyright (c) 2012, 2018 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2012, 2020 embedded brains GmbH. All rights reserved.
* embedded brains GmbH
* Dornierstr. 4
@@ -67,7 +67,8 @@ static const char *const internal_error_text[] = {
"INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED",
"INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT",
"INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL",
- "INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA"
+ "INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA",
+ "INTERNAL_ERROR_TOO_LARGE_TLS_SIZE"
const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/src/tlsallocsize.c b/cpukit/score/src/tlsallocsize.c
index 8fa5600602..a9f0c0cd23 100644
--- a/cpukit/score/src/tlsallocsize.c
+++ b/cpukit/score/src/tlsallocsize.c
@@ -1,7 +1,7 @@
- * SPDX-License-Identifier: BSD-2-Clause
- * Copyright (C) 2014, 2019 embedded brains GmbH
+ * Copyright (C) 2014, 2020 embedded brains GmbH (http://www.embedded-brains.de)
* modification, are permitted provided that the following conditions
@@ -30,6 +30,8 @@
#endif
#include <rtems/score/tls.h>
+#include <rtems/score/interr.h>
+#include <rtems/score/thread.h>
static uintptr_t _TLS_Allocation_size;
@@ -65,6 +67,14 @@ uintptr_t _TLS_Get_allocation_size( void )
allocation_size += sizeof(TLS_Dynamic_thread_vector);
#endif
+ if ( _Thread_Maximum_TLS_size != 0 ) {
+ if ( allocation_size <= _Thread_Maximum_TLS_size ) {
+ allocation_size = _Thread_Maximum_TLS_size;
+ } else {
+ _Internal_error( INTERNAL_ERROR_TOO_LARGE_TLS_SIZE );
_TLS_Allocation_size = allocation_size;
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index adb5ade354..64b0a54b0e 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -256,6 +256,8 @@ links:
uid: spfatal31
- role: build-dependency
uid: spfatal32
+- role: build-dependency
+ uid: spfatal33
uid: spfifo01
diff --git a/spec/build/testsuites/sptests/spfatal33.yml b/spec/build/testsuites/sptests/spfatal33.yml
new file mode 100644
index 0000000000..4280f7059d
--- /dev/null
+++ b/spec/build/testsuites/sptests/spfatal33.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/spfatal33/init.c
+stlib: []
+target: testsuites/sptests/spfatal33.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/sptests/spfatal33/init.c b/testsuites/sptests/spfatal33/init.c
index 0000000000..3cdce7d931
--- /dev/null
+++ b/testsuites/sptests/spfatal33/init.c
@@ -0,0 +1,55 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "../spfatal_support/spfatal.h"
+#define FATAL_ERROR_TEST_NAME "33"
+#define FATAL_ERROR_DESCRIPTION "provoke too large TLS size"
+#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
+#define FATAL_ERROR_EXPECTED_ERROR INTERNAL_ERROR_TOO_LARGE_TLS_SIZE
+static _Thread_local short tls;
+static void force_error(void)
+ long var;
+ var = tls;
+ RTEMS_OBFUSCATE_VARIABLE( var );
+ tls = var;
+ /* Not reached */
+ rtems_test_assert( 0 );
+#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE 1
+#include "../spfatal_support/spfatalimpl.h"
diff --git a/testsuites/sptests/spfatal33/spfatal33.doc b/testsuites/sptests/spfatal33/spfatal33.doc
index 0000000000..190e1ad4eb
--- /dev/null
+++ b/testsuites/sptests/spfatal33/spfatal33.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spfatal33
+directives:
+ - _TLS_Get_allocation_size()
+concepts:
+ - Provoke a too large TLS size.
diff --git a/testsuites/sptests/spfatal33/spfatal33.scn b/testsuites/sptests/spfatal33/spfatal33.scn
index 0000000000..80e3dd40a4
--- /dev/null
+++ b/testsuites/sptests/spfatal33/spfatal33.scn
@@ -0,0 +1,16 @@
+*** BEGIN OF TEST SPFATAL 33 ***
+*** TEST VERSION: 6.0.0.40a6a37e27a5e112bb3e383c196c6094f3498298
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_DEBUG
+*** TEST TOOLS: 10.2.1 20200904 (RTEMS 6, RSB 47f32b8b1a597b5ed3475722bdc155249ef51115, Newlib a0d7982)
+Fatal error (provoke too large TLS size) hit
+*** END OF TEST SPFATAL 33 ***
+*** FATAL ***
+fatal source: 0 (INTERNAL_ERROR_CORE)
+fatal code: 41 (INTERNAL_ERROR_TOO_LARGE_TLS_SIZE)
+RTEMS version: 6.0.0.40a6a37e27a5e112bb3e383c196c6094f3498298
+RTEMS tools: 10.2.1 20200904 (RTEMS 6, RSB 47f32b8b1a597b5ed3475722bdc155249ef51115, Newlib a0d7982)
+executing thread is NULL
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index bf589473de..1b7d0b4388 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -1,5 +1,5 @@
* Donierstr. 4
@@ -36,7 +36,7 @@ static void test_internal_error_text(void)
} while ( text != text_last );
rtems_test_assert(
- error - 3 == INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA
+ error - 3 == INTERNAL_ERROR_TOO_LARGE_TLS_SIZE
2.26.2
