[PATCH v5 7/7] validation: rtems_task_construct() errors
Wed Sep 16 14:49:10 UTC 2020
This is the first test case generated from a specification item in the
rtems-central repository.
Update #3959.
 .../testsuites/validation/validation-0.yml    |    1 +
 .../validation/tc-task-construct-errors.c     | 2367 +++++++++++++++++
 2 files changed, 2368 insertions(+)
 create mode 100644 testsuites/validation/tc-task-construct-errors.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index d024efb96f..edc0b570ae 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -11,6 +11,7 @@ includes: []
 ldflags: []
 links: []
 source:
+- testsuites/validation/tc-task-construct-errors.c
 - testsuites/validation/ts-validation-0.c
 stlib: []
 target: testsuites/validation/ts-validation-0.exe
diff --git a/testsuites/validation/tc-task-construct-errors.c b/testsuites/validation/tc-task-construct-errors.c
new file mode 100644
index 0000000000..615186e092
--- /dev/null
+++ b/testsuites/validation/tc-task-construct-errors.c
@@ -0,0 +1,2367 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsTaskReqConstructErrors
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file was automatically generated.  Do not edit it manually.
+ * Please have a look at
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+ * for information how to maintain and re-generate this file.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <string.h>
+#include <rtems/score/chainimpl.h>
+#include <rtems/score/objectimpl.h>
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsTaskReqConstructErrors \
+ *   spec:/rtems/task/req/construct-errors
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_Id_Id,
+  RtemsTaskReqConstructErrors_Pre_Id_Null,
+  RtemsTaskReqConstructErrors_Pre_Id_NA
+} RtemsTaskReqConstructErrors_Pre_Id;
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_Name_Valid,
+  RtemsTaskReqConstructErrors_Pre_Name_Inv,
+  RtemsTaskReqConstructErrors_Pre_Name_NA
+} RtemsTaskReqConstructErrors_Pre_Name;
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_Prio_Valid,
+  RtemsTaskReqConstructErrors_Pre_Prio_Zero,
+  RtemsTaskReqConstructErrors_Pre_Prio_Inv,
+  RtemsTaskReqConstructErrors_Pre_Prio_NA
+} RtemsTaskReqConstructErrors_Pre_Prio;
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_Tasks_Avail,
+  RtemsTaskReqConstructErrors_Pre_Tasks_None,
+  RtemsTaskReqConstructErrors_Pre_Tasks_NA
+} RtemsTaskReqConstructErrors_Pre_Tasks;
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_TLS_Enough,
+  RtemsTaskReqConstructErrors_Pre_TLS_Small,
+  RtemsTaskReqConstructErrors_Pre_TLS_NA
+} RtemsTaskReqConstructErrors_Pre_TLS;
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_Stack_Enough,
+  RtemsTaskReqConstructErrors_Pre_Stack_Small,
+  RtemsTaskReqConstructErrors_Pre_Stack_NA
+} RtemsTaskReqConstructErrors_Pre_Stack;
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_Ext_Ok,
+  RtemsTaskReqConstructErrors_Pre_Ext_Err,
+  RtemsTaskReqConstructErrors_Pre_Ext_NA
+} RtemsTaskReqConstructErrors_Pre_Ext;
+typedef enum {
+  RtemsTaskReqConstructErrors_Pre_Preempt_Yes,
+  RtemsTaskReqConstructErrors_Pre_Preempt_No,
+  RtemsTaskReqConstructErrors_Pre_Preempt_NA
+} RtemsTaskReqConstructErrors_Pre_Preempt;
+typedef enum {
+  RtemsTaskReqConstructErrors_Post_Status_Ok,
+  RtemsTaskReqConstructErrors_Post_Status_InvAddress,
+  RtemsTaskReqConstructErrors_Post_Status_InvName,
+  RtemsTaskReqConstructErrors_Post_Status_InvPrio,
+  RtemsTaskReqConstructErrors_Post_Status_InvSize,
+  RtemsTaskReqConstructErrors_Post_Status_TooMany,
+  RtemsTaskReqConstructErrors_Post_Status_Unsatisfied,
+  RtemsTaskReqConstructErrors_Post_Status_NA
+} RtemsTaskReqConstructErrors_Post_Status;
+ * @brief Test context for spec:/rtems/task/req/construct-errors test case.
+typedef struct {
+  rtems_status_code status;
+  rtems_task_config config;
+  rtems_id *id;
+  rtems_id id_value;
+  bool create_extension_status;
+  size_t stack_size;
+  rtems_id extension_id;
+  Chain_Control tasks;
+   * @brief This member defines the pre-condition states for the next action.
+  size_t pcs[ 8 ];
+   * @brief This member indicates if the test action loop is currently
+   *   executed.
+  bool in_action_loop;
+} RtemsTaskReqConstructErrors_Context;
+static RtemsTaskReqConstructErrors_Context
+  RtemsTaskReqConstructErrors_Instance;
+static const char * const RtemsTaskReqConstructErrors_PreDesc_Id[] = {
+  "Id",
+  "Null",
+  "NA"
+static const char * const RtemsTaskReqConstructErrors_PreDesc_Name[] = {
+  "Valid",
+  "Inv",
+  "NA"
+static const char * const RtemsTaskReqConstructErrors_PreDesc_Prio[] = {
+  "Valid",
+  "Zero",
+  "Inv",
+  "NA"
+static const char * const RtemsTaskReqConstructErrors_PreDesc_Tasks[] = {
+  "Avail",
+  "None",
+  "NA"
+static const char * const RtemsTaskReqConstructErrors_PreDesc_TLS[] = {
+  "Enough",
+  "Small",
+  "NA"
+static const char * const RtemsTaskReqConstructErrors_PreDesc_Stack[] = {
+  "Enough",
+  "Small",
+  "NA"
+static const char * const RtemsTaskReqConstructErrors_PreDesc_Ext[] = {
+  "Ok",
+  "Err",
+  "NA"
+static const char * const RtemsTaskReqConstructErrors_PreDesc_Preempt[] = {
+  "Yes",
+  "No",
+  "NA"
+static const char * const * const RtemsTaskReqConstructErrors_PreDesc[] = {
+  RtemsTaskReqConstructErrors_PreDesc_Id,
+  RtemsTaskReqConstructErrors_PreDesc_Name,
+  RtemsTaskReqConstructErrors_PreDesc_Prio,
+  RtemsTaskReqConstructErrors_PreDesc_Tasks,
+  RtemsTaskReqConstructErrors_PreDesc_TLS,
+  RtemsTaskReqConstructErrors_PreDesc_Stack,
+  RtemsTaskReqConstructErrors_PreDesc_Ext,
+  RtemsTaskReqConstructErrors_PreDesc_Preempt,
+  NULL
+static _Thread_local int tls_variable;
+#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 128, RTEMS_TASK_STORAGE_ALIGNMENT )
+RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT ) static char task_storage[
+  RTEMS_TASK_STORAGE_SIZE(
+    MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_FLOATING_POINT
+static const rtems_task_config valid_task_config = {
+  .name = rtems_build_name( 'T', 'A', 'S', 'K' ),
+  .initial_priority = 1,
+  .storage_area = task_storage,
+  .storage_size = sizeof( task_storage ),
+  .maximum_thread_local_storage_size = MAX_TLS_SIZE,
+  .initial_modes = RTEMS_DEFAULT_MODES,
+  .attributes = RTEMS_DEFAULT_MODES
+static bool ThreadCreate( rtems_tcb *executing, rtems_tcb *created )
+  (void) executing;
+  (void) created;
+  return RtemsTaskReqConstructErrors_Instance.create_extension_status;
+static const rtems_extensions_table extensions = {
+  .thread_create = ThreadCreate
+static void RtemsTaskReqConstructErrors_Pre_Id_Prepare(
+  RtemsTaskReqConstructErrors_Context *ctx,
+  RtemsTaskReqConstructErrors_Pre_Id   state
+  switch ( state ) {
+    case RtemsTaskReqConstructErrors_Pre_Id_Id: {
+      ctx->id = &ctx->id_value;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Id_Null: {
+      ctx->id = NULL;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Id_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Pre_Name_Prepare(
+  RtemsTaskReqConstructErrors_Pre_Name state
+    case RtemsTaskReqConstructErrors_Pre_Name_Valid: {
+      ctx->config.name = rtems_build_name( 'N', 'A', 'M', 'E' );
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Name_Inv: {
+      ctx->config.name = 0;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Name_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Pre_Prio_Prepare(
+  RtemsTaskReqConstructErrors_Pre_Prio state
+    case RtemsTaskReqConstructErrors_Pre_Prio_Valid: {
+      ctx->config.initial_priority = 254;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Prio_Zero: {
+      ctx->config.initial_priority = 0;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Prio_Inv: {
+      ctx->config.initial_priority = 0xffffffff;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Prio_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Pre_Tasks_Prepare(
+  RtemsTaskReqConstructErrors_Pre_Tasks state
+    case RtemsTaskReqConstructErrors_Pre_Tasks_Avail: {
+      /* Nothing to do */
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Tasks_None: {
+      create_extension_status = ctx->create_extension_status;
+      ctx->create_extension_status = true;
+      while ( true ) {
+        rtems_status_code sc;
+        rtems_id id;
+        sc = rtems_task_construct( &valid_task_config, &id );
+        if ( sc == RTEMS_SUCCESSFUL ) {
+          Objects_Control           *obj;
+          const Objects_Information *info;
+          info = _Objects_Get_information_id( id );
+          T_quiet_assert_not_null( info );
+          obj = _Objects_Get_no_protection( id, info );
+          T_quiet_assert_not_null( obj );
+          _Chain_Append_unprotected( &ctx->tasks, &obj->Node );
+        } else {
+          T_quiet_rsc( sc, RTEMS_TOO_MANY );
+          break;
+      ctx->create_extension_status = create_extension_status;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Tasks_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Pre_TLS_Prepare(
+  RtemsTaskReqConstructErrors_Pre_TLS  state
+    case RtemsTaskReqConstructErrors_Pre_TLS_Enough: {
+      ctx->config.maximum_thread_local_storage_size = MAX_TLS_SIZE;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_TLS_Small: {
+      ctx->config.maximum_thread_local_storage_size = 0;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_TLS_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Pre_Stack_Prepare(
+  RtemsTaskReqConstructErrors_Pre_Stack state
+    case RtemsTaskReqConstructErrors_Pre_Stack_Enough: {
+      ctx->stack_size = RTEMS_MINIMUM_STACK_SIZE;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Stack_Small: {
+      ctx->stack_size = 0;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Stack_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Pre_Ext_Prepare(
+  RtemsTaskReqConstructErrors_Pre_Ext  state
+    case RtemsTaskReqConstructErrors_Pre_Ext_Ok: {
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Ext_Err: {
+      ctx->create_extension_status = false;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Ext_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Pre_Preempt_Prepare(
+  RtemsTaskReqConstructErrors_Pre_Preempt state
+    case RtemsTaskReqConstructErrors_Pre_Preempt_Yes: {
+      ctx->config.initial_modes &= ~RTEMS_PREEMPT_MASK;
+      ctx->config.initial_modes |= RTEMS_PREEMPT;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Preempt_No: {
+      ctx->config.initial_modes |= RTEMS_NO_PREEMPT;
+      break;
+    case RtemsTaskReqConstructErrors_Pre_Preempt_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Post_Status_Check(
+  RtemsTaskReqConstructErrors_Post_Status state
+    case RtemsTaskReqConstructErrors_Post_Status_Ok: {
+      T_rsc_success( ctx->status );
+      T_eq_ptr( ctx->id, &ctx->id_value );
+      T_ne_u32( ctx->id_value, 0xffffffff );
+      sc = rtems_task_delete( ctx->id_value );
+      T_rsc_success( sc );
+      break;
+    case RtemsTaskReqConstructErrors_Post_Status_InvAddress: {
+      T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+      T_null( ctx->id );
+      T_eq_u32( ctx->id_value, 0xffffffff );
+      break;
+    case RtemsTaskReqConstructErrors_Post_Status_InvName: {
+      T_rsc( ctx->status, RTEMS_INVALID_NAME );
+      break;
+    case RtemsTaskReqConstructErrors_Post_Status_InvPrio: {
+      T_rsc( ctx->status, RTEMS_INVALID_PRIORITY );
+      break;
+    case RtemsTaskReqConstructErrors_Post_Status_InvSize: {
+      T_rsc( ctx->status, RTEMS_INVALID_SIZE );
+      break;
+    case RtemsTaskReqConstructErrors_Post_Status_TooMany: {
+      T_rsc( ctx->status, RTEMS_TOO_MANY );
+      break;
+    case RtemsTaskReqConstructErrors_Post_Status_Unsatisfied: {
+      T_rsc( ctx->status, RTEMS_UNSATISFIED  );
+      break;
+    case RtemsTaskReqConstructErrors_Post_Status_NA:
+      break;
+static void RtemsTaskReqConstructErrors_Setup(
+  int var;
+  var = tls_variable;
+  RTEMS_OBFUSCATE_VARIABLE( var );
+  tls_variable = var;
+  sc = rtems_extension_create(
+    rtems_build_name( 'T', 'C', 'F', 'C' ),
+    &extensions,
+    &ctx->extension_id
+  _Chain_Initialize_empty( &ctx->tasks );
+static void RtemsTaskReqConstructErrors_Setup_Wrap( void *arg )
+  RtemsTaskReqConstructErrors_Context *ctx;
+  ctx = arg;
+  ctx->in_action_loop = false;
+  RtemsTaskReqConstructErrors_Setup( ctx );
+static void RtemsTaskReqConstructErrors_Teardown(
+  sc = rtems_extension_delete( ctx->extension_id );
+static void RtemsTaskReqConstructErrors_Teardown_Wrap( void *arg )
+  ctx = arg;
+  RtemsTaskReqConstructErrors_Teardown( ctx );
+static size_t RtemsTaskReqConstructErrors_Scope(
+  void  *arg,
+  char  *buf,
+  size_t n
+  ctx = arg;
+  if ( ctx->in_action_loop ) {
+    return T_get_scope(
+      RtemsTaskReqConstructErrors_PreDesc,
+      buf,
+      n,
+      ctx->pcs
+  return 0;
+static T_fixture RtemsTaskReqConstructErrors_Fixture = {
+  .setup = RtemsTaskReqConstructErrors_Setup_Wrap,
+  .stop = NULL,
+  .teardown = RtemsTaskReqConstructErrors_Teardown_Wrap,
+  .scope = RtemsTaskReqConstructErrors_Scope,
+  .initial_context = &RtemsTaskReqConstructErrors_Instance
+static const uint8_t RtemsTaskReqConstructErrors_TransitionMap[][ 1 ] = {
+#if defined(RTEMS_SMP)
+#else
+#endif
+static const struct {
+  uint16_t Skip : 1;
+  uint16_t Pre_Id_NA : 1;
+  uint16_t Pre_Name_NA : 1;
+  uint16_t Pre_Prio_NA : 1;
+  uint16_t Pre_Tasks_NA : 1;
+  uint16_t Pre_TLS_NA : 1;
+  uint16_t Pre_Stack_NA : 1;
+  uint16_t Pre_Ext_NA : 1;
+  uint16_t Pre_Preempt_NA : 1;
+} RtemsTaskReqConstructErrors_TransitionInfo[] = {
+    0, 0, 0, 0, 0, 0, 0, 0, 0
+#else
+#endif
+static void RtemsTaskReqConstructErrors_Prepare(
+  ctx->id_value = 0xffffffff;
+  memset( &ctx->config, 0, sizeof( ctx->config ) );
+static void RtemsTaskReqConstructErrors_Action(
+  ctx->config.storage_size = RTEMS_TASK_STORAGE_SIZE(
+    ctx->config.maximum_thread_local_storage_size + ctx->stack_size,
+    ctx->config.attributes
+  ctx->status = rtems_task_construct( &ctx->config, ctx->id );
+static void RtemsTaskReqConstructErrors_Cleanup(
+  Chain_Node *node;
+  while ( ( node = _Chain_Get_unprotected( &ctx->tasks ) ) ) {
+    obj = (Objects_Control *) node;
+    sc = rtems_task_delete( obj->id );
+    T_quiet_rsc_success( sc );
+ * @fn void T_case_body_RtemsTaskReqConstructErrors( void )
+T_TEST_CASE_FIXTURE(
+  RtemsTaskReqConstructErrors,
+  &RtemsTaskReqConstructErrors_Fixture
+  size_t index;
+  ctx = T_fixture_context();
+  ctx->in_action_loop = true;
+  index = 0;
+  for (
+    ctx->pcs[ 0 ] = RtemsTaskReqConstructErrors_Pre_Id_Id;
+    ctx->pcs[ 0 ] < RtemsTaskReqConstructErrors_Pre_Id_NA;
+    ++ctx->pcs[ 0 ]
+    if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Id_NA ) {
+      ctx->pcs[ 0 ] = RtemsTaskReqConstructErrors_Pre_Id_NA;
+      index += ( RtemsTaskReqConstructErrors_Pre_Id_NA - 1 )
+        * RtemsTaskReqConstructErrors_Pre_Name_NA
+        * RtemsTaskReqConstructErrors_Pre_Prio_NA
+        * RtemsTaskReqConstructErrors_Pre_Tasks_NA
+        * RtemsTaskReqConstructErrors_Pre_TLS_NA
+        * RtemsTaskReqConstructErrors_Pre_Stack_NA
+        * RtemsTaskReqConstructErrors_Pre_Ext_NA
+        * RtemsTaskReqConstructErrors_Pre_Preempt_NA;
+    for (
+      ctx->pcs[ 1 ] = RtemsTaskReqConstructErrors_Pre_Name_Valid;
+      ctx->pcs[ 1 ] < RtemsTaskReqConstructErrors_Pre_Name_NA;
+      ++ctx->pcs[ 1 ]
+      if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Name_NA ) {
+        ctx->pcs[ 1 ] = RtemsTaskReqConstructErrors_Pre_Name_NA;
+        index += ( RtemsTaskReqConstructErrors_Pre_Name_NA - 1 )
+      for (
+        ctx->pcs[ 2 ] = RtemsTaskReqConstructErrors_Pre_Prio_Valid;
+        ctx->pcs[ 2 ] < RtemsTaskReqConstructErrors_Pre_Prio_NA;
+        ++ctx->pcs[ 2 ]
+        if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Prio_NA ) {
+          ctx->pcs[ 2 ] = RtemsTaskReqConstructErrors_Pre_Prio_NA;
+          index += ( RtemsTaskReqConstructErrors_Pre_Prio_NA - 1 )
+        for (
+          ctx->pcs[ 3 ] = RtemsTaskReqConstructErrors_Pre_Tasks_Avail;
+          ctx->pcs[ 3 ] < RtemsTaskReqConstructErrors_Pre_Tasks_NA;
+          ++ctx->pcs[ 3 ]
+          if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Tasks_NA ) {
+            ctx->pcs[ 3 ] = RtemsTaskReqConstructErrors_Pre_Tasks_NA;
+            index += ( RtemsTaskReqConstructErrors_Pre_Tasks_NA - 1 )
+          for (
+            ctx->pcs[ 4 ] = RtemsTaskReqConstructErrors_Pre_TLS_Enough;
+            ctx->pcs[ 4 ] < RtemsTaskReqConstructErrors_Pre_TLS_NA;
+            ++ctx->pcs[ 4 ]
+            if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_TLS_NA ) {
+              ctx->pcs[ 4 ] = RtemsTaskReqConstructErrors_Pre_TLS_NA;
+              index += ( RtemsTaskReqConstructErrors_Pre_TLS_NA - 1 )
+            for (
+              ctx->pcs[ 5 ] = RtemsTaskReqConstructErrors_Pre_Stack_Enough;
+              ctx->pcs[ 5 ] < RtemsTaskReqConstructErrors_Pre_Stack_NA;
+              ++ctx->pcs[ 5 ]
+              if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Stack_NA ) {
+                ctx->pcs[ 5 ] = RtemsTaskReqConstructErrors_Pre_Stack_NA;
+                index += ( RtemsTaskReqConstructErrors_Pre_Stack_NA - 1 )
+              for (
+                ctx->pcs[ 6 ] = RtemsTaskReqConstructErrors_Pre_Ext_Ok;
+                ctx->pcs[ 6 ] < RtemsTaskReqConstructErrors_Pre_Ext_NA;
+                ++ctx->pcs[ 6 ]
+                if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Ext_NA ) {
+                  ctx->pcs[ 6 ] = RtemsTaskReqConstructErrors_Pre_Ext_NA;
+                  index += ( RtemsTaskReqConstructErrors_Pre_Ext_NA - 1 )
+                for (
+                  ctx->pcs[ 7 ] = RtemsTaskReqConstructErrors_Pre_Preempt_Yes;
+                  ctx->pcs[ 7 ] < RtemsTaskReqConstructErrors_Pre_Preempt_NA;
+                  ++ctx->pcs[ 7 ]
+                  if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Pre_Preempt_NA ) {
+                    ctx->pcs[ 7 ] = RtemsTaskReqConstructErrors_Pre_Preempt_NA;
+                    index += ( RtemsTaskReqConstructErrors_Pre_Preempt_NA - 1 );
+                  if ( RtemsTaskReqConstructErrors_TransitionInfo[ index ].Skip ) {
+                    ++index;
+                    continue;
+                  RtemsTaskReqConstructErrors_Prepare( ctx );
+                  RtemsTaskReqConstructErrors_Pre_Id_Prepare(
+                    ctx,
+                    ctx->pcs[ 0 ]
+                  RtemsTaskReqConstructErrors_Pre_Name_Prepare(
+                    ctx,
+                    ctx->pcs[ 1 ]
+                  RtemsTaskReqConstructErrors_Pre_Prio_Prepare(
+                    ctx,
+                    ctx->pcs[ 2 ]
+                  RtemsTaskReqConstructErrors_Pre_Tasks_Prepare(
+                    ctx,
+                    ctx->pcs[ 3 ]
+                  RtemsTaskReqConstructErrors_Pre_TLS_Prepare(
+                    ctx,
+                    ctx->pcs[ 4 ]
+                  RtemsTaskReqConstructErrors_Pre_Stack_Prepare(
+                    ctx,
+                    ctx->pcs[ 5 ]
+                  RtemsTaskReqConstructErrors_Pre_Ext_Prepare(
+                    ctx,
+                    ctx->pcs[ 6 ]
+                  RtemsTaskReqConstructErrors_Pre_Preempt_Prepare(
+                    ctx,
+                    ctx->pcs[ 7 ]
+                  RtemsTaskReqConstructErrors_Action( ctx );
+                  RtemsTaskReqConstructErrors_Post_Status_Check(
+                    ctx,
+                    RtemsTaskReqConstructErrors_TransitionMap[ index ][ 0 ]
+                  RtemsTaskReqConstructErrors_Cleanup( ctx );
+                  ++index;
2.26.2
