[PATCH v5 0/7] Add rtems_task_construct()
Chris Johns
chrisj at rtems.org
Wed Sep 16 23:39:46 UTC 2020
Looks good.
Thanks for your patience as we worked through this change. I think the outcome
is solid and reflects the efforts made.
On 17/9/20 12:49 am, Sebastian Huber wrote:
> v2:
> Rename function from rtems_task_build() to
> rtems_task_create_from_config(). Add RTEMS_TASK_STORAGE_ALIGNMENT and
> RTEMS_TASK_STORAGE_SIZE(). Improve documentation.
> v3:
> Add CONFIGURE_TASKS_CREATED_FROM_CONFIG. Fix RTEMS_TASK_STORAGE_SIZE() if
> CPU_ALL_TASKS_ARE_FP == TRUE.
> v4:
> Add CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE to control the maximum size
> reserved for thread-local storage.
> Add maximum_thread_local_storage_size member to rtems_task_config to check that
> the thread-local storage size in the task configuration is sufficient for the
> actual thread-local storage size of the application.
> Add a general purpose test suite for basic validation tests. Add a validation
> test case to check the rtems_task_create_from_config() error cases. The code
> is generated from specification items:
> https://git.rtems.org/rtems-central/tree/spec/testsuites/validation-0.yml
> https://git.rtems.org/rtems-central/tree/spec/req/rtems/tasks/create-from-config-errors.yml
> The build system part of the new tests is not included in the patch set. I
> don't want to add a new test suite for the old build system.
> v5:
> Rename rtems_task_create_from_config() in rtems_task_construct().
> Rename CONFIGURE_TASKS_CREATED_FROM_CONFIG in
> CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE.
> Add RTEMS_ALIGN_DOWN() and RTEMS_ALIGN_UP().
> Change RTEMS_TASK_STORAGE_ALIGNMENT to be an integer instead of a
> variable attribute.
> The item used to generate the test case is this:
> https://git.rtems.org/rtems-central/tree/spec/rtems/task/req/construct-errors.yml
> Update documentation according to review comments.
> Sebastian Huber (7):
> rtems: Add RTEMS_ALIGN_DOWN()
> rtems: Add RTEMS_ALIGN_UP()
> rtems: Add rtems_task_construct()
> doxygen: Move top-level group definitions
> validation: Add general purpose test suite
> validation: rtems_task_construct() errors
> Doxyfile | 2 +-
> cpukit/doxygen.h | 18 -
> cpukit/doxygen/appl-config.h | 60 +
> cpukit/doxygen/top-level-groups.h | 50 +
> cpukit/include/rtems/confdefs/threads.h | 15 +
> cpukit/include/rtems/confdefs/wkspace.h | 4 +-
> cpukit/include/rtems/rtems/tasks.h | 193 ++
> cpukit/include/rtems/rtems/tasksimpl.h | 11 +
> cpukit/include/rtems/score/basedefs.h | 30 +
> cpukit/include/rtems/score/interr.h | 3 +-
> cpukit/include/rtems/score/thread.h | 10 +
> cpukit/rtems/src/taskconstruct.c | 300 +++
> cpukit/rtems/src/taskcreate.c | 282 +-
> cpukit/sapi/src/interrtext.c | 5 +-
> cpukit/score/src/tlsallocsize.c | 16 +-
> spec/build/cpukit/librtemscpu.yml | 1 +
> spec/build/testsuites/grp.yml | 4 +
> spec/build/testsuites/optvalidation.yml | 15 +
> spec/build/testsuites/sptests/grp.yml | 2 +
> spec/build/testsuites/sptests/spfatal33.yml | 19 +
> spec/build/testsuites/validation/grp.yml | 18 +
> .../testsuites/validation/validation-0.yml | 20 +
> testsuites/sptests/sp01/init.c | 24 +-
> testsuites/sptests/sp01/sp01.doc | 1 +
> testsuites/sptests/sp01/system.h | 3 +-
> testsuites/sptests/spfatal33/init.c | 55 +
> testsuites/sptests/spfatal33/spfatal33.doc | 11 +
> testsuites/sptests/spfatal33/spfatal33.scn | 16 +
> testsuites/sptests/spinternalerror02/init.c | 4 +-
> .../validation/tc-task-construct-errors.c | 2367 +++++++++++++++++
> testsuites/validation/ts-validation-0.c | 222 ++
> 31 files changed, 3518 insertions(+), 263 deletions(-)
> create mode 100644 cpukit/doxygen/top-level-groups.h
> create mode 100644 cpukit/rtems/src/taskconstruct.c
> create mode 100644 spec/build/testsuites/optvalidation.yml
> create mode 100644 spec/build/testsuites/sptests/spfatal33.yml
> create mode 100644 spec/build/testsuites/validation/grp.yml
> create mode 100644 spec/build/testsuites/validation/validation-0.yml
> create mode 100644 testsuites/sptests/spfatal33/init.c
> create mode 100644 testsuites/sptests/spfatal33/spfatal33.doc
> create mode 100644 testsuites/sptests/spfatal33/spfatal33.scn
> create mode 100644 testsuites/validation/tc-task-construct-errors.c
> create mode 100644 testsuites/validation/ts-validation-0.c
