RTEMS BSP Builder and New/Old Build System
Chris Johns
chrisj at rtems.org
Wed Sep 16 23:34:20 UTC 2020
On 17/9/20 8:12 am, Joel Sherrill wrote:
> Just noting that it would be nice to have a transition period where RTEMS BSP
> Builder supported both build systems for comparison purposes.
I prefer this be as short as possible. What about 1st Nov 2020?
It is not clear what the criteria is to trigger removal of the old build system.
We do not want a set of rules that are difficult to meet stalling the removal.
If you would like to meet some criteria please documented it on this page:
https://devel.rtems.org/wiki/Release/6/Waf%20BSP%20Checklist
The columns in the table are the checklists but there are no rules on what needs
to be completed. It was intended to be a status.
The new build system is way better to work with and if a user reports an issue
we should be able to sort it out. The 5.1 release is the old build system base
line once it is removed from master.
