[PATCH rtems-libbsd 1/3] Add helper script to find licenses.
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Sep 18 06:39:19 UTC 2020
On 17/09/2020 23:35, Chris Johns wrote:
> On 17/9/20 10:51 pm, Joel Sherrill wrote:
>> I think I'm ok on all three of these patches but some
>> comments on the shell script. I can see where this is a
>> tedious but important check. And it can be improved easily.
>> Since this smells like something Chris would poke me f
>> or and call a "Joel script" :)
> Haha ...
> This patch is only for the 5-freesd-12 branch and a script is fine. The script
> has made think for the master and 6-freebsd-12 branches libbsd.py should be
> taught to handle licenses so these are copied across as part of the import.
> Chris
Hello Chris and Joel,
I agree that this script is an ugly one. It has been hacked together
when I needed to import the license files and I didn't wanted to throw
it out of the window because I thought it might could be useful to find
some more missing license files in the future.
Please note that this script is already on master since quite a long
time and that I only cherry-picked the commits for the 5-freebsd-12
branch (and adapted the import patch to import the right version). So
thanks for the suggestions Joel but shouldn't these changes then be an
extra patch? Chris: You mentioned that libbsd.py should be taught to
handle licenses. Do you plan anything into that direction? In that case
touching the script wouldn't be really useful.
Best regards
Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
