[PATCH 2/6] rtems: From <rtems.h> to <rtems/rtems/object.h>
Sebastian Huber
Fri Sep 18 07:34:52 UTC 2020
Move object related declarations and definitions to
<rtems/rtems/object.h>. The goal is to make <rtems.h> an include only
header file.
cpukit/include/rtems.h | 59 -----------------------------
cpukit/include/rtems/rtems/object.h | 59 +++++++++++++++++++++++++++++
2 files changed, 59 insertions(+), 59 deletions(-)
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index 6bdca97769..763b1e7fc3 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -62,65 +62,6 @@
extern "C" {
#endif
- * CONSTANTS WHICH MAY BE USED IN OBJECT NAME TO ID SEARCHES
- * @brief Indicates that a search is across all nodes.
-#define RTEMS_SEARCH_ALL_NODES OBJECTS_SEARCH_ALL_NODES
- * @brief Indicates that a search is across all nodes except the one the call
- * is made from.
-#define RTEMS_SEARCH_OTHER_NODES OBJECTS_SEARCH_OTHER_NODES
- * @brief Indicates that the search is to be restricted to the local node.
-#define RTEMS_SEARCH_LOCAL_NODE OBJECTS_SEARCH_LOCAL_NODE
- * @brief Indicates that the caller wants to obtain the name of the currently
- * executing thread.
- * This constant is only meaningful when obtaining the name of a task.
-#define RTEMS_WHO_AM_I OBJECTS_WHO_AM_I
- * Parameters and return Id's for _Objects_Get_next
- * @brief Lowest valid index value for the index portion of an object
- * identifier.
-#define RTEMS_OBJECT_ID_INITIAL_INDEX OBJECTS_ID_INITIAL_INDEX
- * @brief Maximum valid index value for the index portion of an object
- * identifier.
-#define RTEMS_OBJECT_ID_FINAL_INDEX OBJECTS_ID_FINAL_INDEX
- * @brief Returns the identifier of the object with the lowest valid index
- * value.
- * The object is specified by the API @a _api, the object class @a _class and
- * the node @a _node where the object resides.
-#define RTEMS_OBJECT_ID_INITIAL(_api, _class, _node) \
- OBJECTS_ID_INITIAL(_api, _class, _node)
- * @brief Maximum valid object identifier.
-#define RTEMS_OBJECT_ID_FINAL OBJECTS_ID_FINAL
* @brief Minimum stack size which every thread must exceed.
diff --git a/cpukit/include/rtems/rtems/object.h b/cpukit/include/rtems/rtems/object.h
index d6ae058425..8e8bfbf293 100644
--- a/cpukit/include/rtems/rtems/object.h
+++ b/cpukit/include/rtems/rtems/object.h
@@ -367,6 +367,65 @@ RTEMS_INLINE_ROUTINE uint16_t rtems_object_get_local_node( void )
return _Objects_Local_node;
+ * CONSTANTS WHICH MAY BE USED IN OBJECT NAME TO ID SEARCHES
+ * @brief Indicates that a search is across all nodes.
+#define RTEMS_SEARCH_ALL_NODES OBJECTS_SEARCH_ALL_NODES
+ * @brief Indicates that a search is across all nodes except the one the call
+ * is made from.
+#define RTEMS_SEARCH_OTHER_NODES OBJECTS_SEARCH_OTHER_NODES
+ * @brief Indicates that the search is to be restricted to the local node.
+#define RTEMS_SEARCH_LOCAL_NODE OBJECTS_SEARCH_LOCAL_NODE
+ * @brief Indicates that the caller wants to obtain the name of the currently
+ * executing thread.
+ * This constant is only meaningful when obtaining the name of a task.
+#define RTEMS_WHO_AM_I OBJECTS_WHO_AM_I
+ * Parameters and return Id's for _Objects_Get_next
+ * @brief Lowest valid index value for the index portion of an object
+ * identifier.
+#define RTEMS_OBJECT_ID_INITIAL_INDEX OBJECTS_ID_INITIAL_INDEX
+ * @brief Maximum valid index value for the index portion of an object
+ * identifier.
+#define RTEMS_OBJECT_ID_FINAL_INDEX OBJECTS_ID_FINAL_INDEX
+ * @brief Returns the identifier of the object with the lowest valid index
+ * value.
+ * The object is specified by the API @a _api, the object class @a _class and
+ * the node @a _node where the object resides.
+#define RTEMS_OBJECT_ID_INITIAL(_api, _class, _node) \
+ OBJECTS_ID_INITIAL(_api, _class, _node)
+ * @brief Maximum valid object identifier.
+#define RTEMS_OBJECT_ID_FINAL OBJECTS_ID_FINAL
#ifdef __cplusplus
#endif
2.26.2
