[PATCH 1/6] rtems: Move from <rtems.h> to <rtems/config.h>
Sebastian Huber
Fri Sep 18 07:34:51 UTC 2020
Move configuration related declarations and definitions to
<rtems/config.h>. The goal is to make <rtems.h> an include only header
file.
cpukit/include/rtems.h | 16 ----------------
cpukit/include/rtems/config.h | 17 +++++++++++++++++
cpukit/sapi/src/getcopyrightnotice.c | 2 +-
cpukit/sapi/src/getversionstring.c | 2 +-
4 files changed, 19 insertions(+), 18 deletions(-)
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index 4392f08ce8..6bdca97769 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -62,22 +62,6 @@
extern "C" {
#endif
- * @brief Returns the pointer to the RTEMS copyright notice.
-const char *rtems_get_copyright_notice(void);
- * @brief Returns the pointer to the RTEMS version string.
-const char *rtems_get_version_string(void);
- * @brief Indicates whether this processor variant has hardware floating point
- * support.
-#define RTEMS_HAS_HARDWARE_FP CPU_HARDWARE_FP
* CONSTANTS WHICH MAY BE USED IN OBJECT NAME TO ID SEARCHES
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index e82c7abf11..1fbcf22f2e 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -27,6 +27,7 @@
* the configuration table.
+#include <rtems/score/cpu.h>
#include <rtems/score/isr.h>
#include <rtems/score/memory.h>
@@ -164,6 +165,22 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
#define rtems_configuration_get_maximum_processors() \
(_SMP_Processor_configured_maximum)
+ * @brief Returns the pointer to the RTEMS copyright notice.
+const char *rtems_get_copyright_notice(void);
+ * @brief Returns the pointer to the RTEMS version string.
+const char *rtems_get_version_string(void);
+ * @brief Indicates whether this processor variant has hardware floating point
+ * support.
+#define RTEMS_HAS_HARDWARE_FP CPU_HARDWARE_FP
#ifdef __cplusplus
#endif
diff --git a/cpukit/sapi/src/getcopyrightnotice.c b/cpukit/sapi/src/getcopyrightnotice.c
index 4e5df66524..cd601254e6 100644
--- a/cpukit/sapi/src/getcopyrightnotice.c
+++ b/cpukit/sapi/src/getcopyrightnotice.c
@@ -39,7 +39,7 @@
#pragma GCC diagnostic ignored "-Wdeprecated-declarations"
-#include <rtems.h>
+#include <rtems/config.h>
#include <rtems/score/copyrt.h>
const char *rtems_get_copyright_notice( void )
diff --git a/cpukit/sapi/src/getversionstring.c b/cpukit/sapi/src/getversionstring.c
index a036fe2fbf..f8380f7b4f 100644
--- a/cpukit/sapi/src/getversionstring.c
+++ b/cpukit/sapi/src/getversionstring.c
@@ -19,7 +19,7 @@
#include "config.h"
#endif
-#include <rtems.h>
2.26.2
