[PATCH 5/6] rtems: From <rtems.h> to <rtems/rtems/mp.h>
Sebastian Huber
Fri Sep 18 07:34:55 UTC 2020
Move multiprocessing related definitions to <rtems/rtems/mp.h>. This
makes <rtems.h> an include only header file.
cpukit/include/rtems.h | 25 -------------------------
cpukit/include/rtems/rtems/mp.h | 16 ++++++++++++++++
2 files changed, 16 insertions(+), 25 deletions(-)
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index ff0cb69bcf..dc0472b233 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -24,7 +24,6 @@
* @brief RTEMS Classic API definitions and modules.
@@ -57,29 +56,5 @@
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @brief An MPCI must support packets of at least this size.
-#define RTEMS_MINIMUM_PACKET_SIZE MP_PACKET_MINIMUM_PACKET_SIZE
- * @brief Defines the count of @c uint32_t numbers in a packet which must be
- * converted to native format in a heterogeneous system.
- * In packets longer than this value, some of the extra data may be a user
- * message buffer which is not automatically endian swapped.
-#define RTEMS_MINIMUN_HETERO_CONVERSION MP_PACKET_MINIMUN_HETERO_CONVERSION
-#ifdef __cplusplus
-#endif
#endif
/* end of include file */
diff --git a/cpukit/include/rtems/rtems/mp.h b/cpukit/include/rtems/rtems/mp.h
index a3de1e6682..0ddeaf7d53 100644
--- a/cpukit/include/rtems/rtems/mp.h
+++ b/cpukit/include/rtems/rtems/mp.h
@@ -18,6 +18,8 @@
#ifndef _RTEMS_RTEMS_MP_H
#define _RTEMS_RTEMS_MP_H
+#include <rtems/score/mppkt.h>
* @defgroup ClassicMP Multiprocessing
@@ -32,6 +34,20 @@
extern "C" {
#endif
+ * @brief An MPCI must support packets of at least this size.
+#define RTEMS_MINIMUM_PACKET_SIZE MP_PACKET_MINIMUM_PACKET_SIZE
+ * @brief Defines the count of @c uint32_t numbers in a packet which must be
+ * converted to native format in a heterogeneous system.
+ * In packets longer than this value, some of the extra data may be a user
+ * message buffer which is not automatically endian swapped.
+#define RTEMS_MINIMUN_HETERO_CONVERSION MP_PACKET_MINIMUN_HETERO_CONVERSION
* @brief RTEMS Multiprocessing Announce
2.26.2
