[PATCH 6/6] rtems: Generate <rtems.h>
Fri Sep 18 07:34:56 UTC 2020
Change license to BSD-2-Clause according to file history and
documentation re-licensing agreement.
Update #3053.
Update #3899.
Update #3993.
 cpukit/include/rtems.h | 100 +++++++++++++++++++++++++++--------------
 1 file changed, 67 insertions(+), 33 deletions(-)
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index dc0472b233..cda2bd5b24 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -1,60 +1,94 @@
  * @file
  * @ingroup RTEMSAPIClassic
- * the Public Interface to the RTEMS Classic API
+ * @brief This header file defines the RTEMS Classic API.
-/* COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
-#ifndef _RTEMS_H
-#define _RTEMS_H
- * @defgroup RTEMSAPIClassic Classic
+ * This file was automatically generated.  Do not edit it manually.
+ * Please have a look at
- * @ingroup RTEMSAPI
- * @brief RTEMS Classic API definitions and modules.
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+ * for information how to maintain and re-generate this file.
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/types.h>
+#ifndef _RTEMS_H
+#define _RTEMS_H
 #include <rtems/config.h>
+#include <rtems/extension.h>
+#include <rtems/fatal.h>
 #include <rtems/init.h>
-#include <rtems/rtems/options.h>
-#include <rtems/rtems/tasks.h>
-#include <rtems/rtems/intr.h>
+#include <rtems/io.h>
 #include <rtems/rtems/barrier.h>
 #include <rtems/rtems/cache.h>
 #include <rtems/rtems/clock.h>
-#include <rtems/extension.h>
-#include <rtems/rtems/timer.h>
-#include <rtems/rtems/sem.h>
-#include <rtems/rtems/message.h>
-#include <rtems/rtems/event.h>
-#include <rtems/rtems/signal.h>
+#include <rtems/rtems/dpmem.h>
+#include <rtems/rtems/intr.h>
+#include <rtems/rtems/message.h>
 #include <rtems/rtems/object.h>
+#include <rtems/rtems/options.h>
 #include <rtems/rtems/part.h>
-#include <rtems/rtems/region.h>
-#include <rtems/rtems/dpmem.h>
-#include <rtems/io.h>
-#include <rtems/fatal.h>
 #include <rtems/rtems/ratemon.h>
+#include <rtems/rtems/region.h>
+#include <rtems/rtems/sem.h>
+#include <rtems/rtems/signal.h>
+#include <rtems/rtems/status.h>
+#include <rtems/rtems/support.h>
+#include <rtems/rtems/tasks.h>
+#include <rtems/rtems/timer.h>
+#include <rtems/rtems/types.h>
 #if defined(RTEMS_MULTIPROCESSING)
-#include <rtems/rtems/mp.h>
+  #include <rtems/rtems/mp.h>
 #endif
-#include <rtems/rtems/support.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMSAPIClassic Classic
+ * @ingroup RTEMSAPI
+ * @brief This group contains the Classic API groups.
+#ifdef __cplusplus
 #endif
-/* end of include file */
+#endif /* _RTEMS_H */
2.26.2
