[rtems commit] build: Fix linker path
Mon Sep 21 05:08:06 UTC 2020
On 21/09/2020 07:03, Chris Johns wrote:
>>>> In the long run, the GCC defined start files should be provided by GCC.  This
>>>> is a GCC 11 topic.
>>> It would have been good to discuss this.
>> Without this patch its not possible to use powerpc BSPs. Now the rtems-examples
>> build for all BSPs with some ENOMEM exceptions:
>> https://devel.rtems.org/wiki/Release/6/Waf%20BSP%20Checklist
> That is fine, I was interesting in the GCC 11 topic and what it means.
In order to change things in the CRT files in GCC you have to do this in
the right GCC development phase. Also back ports of this stuff are not
allowed.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
