[rtems commit] build: Fix linker path
Mon Sep 21 05:03:13 UTC 2020
On 21/9/20 2:49 pm, Sebastian Huber wrote:
> On 21/09/2020 01:06, Chris Johns wrote:
>> On 21/9/20 1:32 am, Sebastian Huber wrote:
>>> Use -B for the linker since some architectures use extra start files defined by
>>> the GCC specification and provided by the BSP, for example powerpc.  Start
>>> files are not found by -L.
>> This is the issue I was thinking about when we discussed the spec files the
>> other day. I am wondered if a linker command file could solve this without
>> reverting to spec files. I thought linker command files could specify these
>> platform specific start object files and control what happens. I however could
>> be wrong.
> Sorry for the wrong comment in the commit message. The start files are found by
> -L, the problem are the CRT begin and end files. You cannot specify them in
> linker scripts. I think we already talked about this when we moved the stuff
> from bsp_specs to GCC.
Yes, it is a strange corner case I would need to look to clear my
misunderstanding. It will need to wait for a rainy day or something like that.
>>> In the long run, the GCC defined start files should be provided by GCC.  This
>>> is a GCC 11 topic.
>> It would have been good to discuss this.
> Without this patch its not possible to use powerpc BSPs. Now the rtems-examples
> build for all BSPs with some ENOMEM exceptions:
> https://devel.rtems.org/wiki/Release/6/Waf%20BSP%20Checklist
That is fine, I was interesting in the GCC 11 topic and what it means.
Thanks
Chrs
