[PATCH v2 6/9] score: Add <rtems/score/coremsgbuffer.h>
Fri Sep 25 09:51:29 UTC 2020
Move the CORE_message_queue_Buffer definition to a separate header file to be
able to use it independent of the remaining Message Queue Handler API.
Change license to BSD-2-Clause according to file history.
Update #3053.
Update #4007.
 cpukit/headers.am                          |  1 +
 cpukit/include/rtems/score/coremsg.h       | 39 +--------
 cpukit/include/rtems/score/coremsgbuffer.h | 96 ++++++++++++++++++++++
 spec/build/cpukit/librtemscpu.yml          |  1 +
 4 files changed, 99 insertions(+), 38 deletions(-)
 create mode 100644 cpukit/include/rtems/score/coremsgbuffer.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 77df5ecb4c..23a84ca243 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -335,6 +335,7 @@ include_rtems_score_HEADERS += include/rtems/score/copyrt.h
 include_rtems_score_HEADERS += include/rtems/score/corebarrier.h
 include_rtems_score_HEADERS += include/rtems/score/corebarrierimpl.h
 include_rtems_score_HEADERS += include/rtems/score/coremsg.h
+include_rtems_score_HEADERS += include/rtems/score/coremsgbuffer.h
 include_rtems_score_HEADERS += include/rtems/score/coremsgimpl.h
 include_rtems_score_HEADERS += include/rtems/score/coremutex.h
 include_rtems_score_HEADERS += include/rtems/score/coremuteximpl.h
diff --git a/cpukit/include/rtems/score/coremsg.h b/cpukit/include/rtems/score/coremsg.h
index 2131fa0765..220c9839a5 100644
--- a/cpukit/include/rtems/score/coremsg.h
+++ b/cpukit/include/rtems/score/coremsg.h
@@ -21,7 +21,7 @@
 #ifndef _RTEMS_SCORE_COREMSG_H
 #define _RTEMS_SCORE_COREMSG_H
-#include <rtems/score/chain.h>
+#include <rtems/score/coremsgbuffer.h>
 #include <rtems/score/isrlock.h>
 #include <rtems/score/threadq.h>
@@ -43,13 +43,6 @@ extern "C" {
- *  This macro is defined when an API is enabled that requires that the
- *  Message Queue Handler include support for priority based enqueuing
- *  of messages.
-#define RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY
 #if defined(RTEMS_POSIX_API)
@@ -67,36 +60,6 @@ extern "C" {
 typedef struct CORE_message_queue_Control CORE_message_queue_Control;
- * @brief The structure is used to organize message buffers of a message queue.
-typedef struct {
-   * @brief This member is used to enqueue the buffer in the pending or free
-   *   buffer queue of a message queue.
-  Chain_Node Node;
-  /** @brief This member defines the size of this message. */
-  size_t size;
-#if defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
-  /** @brief This member defines the priority of this message. */
-  int priority;
-#endif
-   * @brief This member contains the actual message.
-   * This is a zero-length array since the maximum message size is defined by
-   * the user.  Use a size_t array to make sure that the member offset is at
-   * the structure end.  This enables a more efficient memcpy() on 64-bit
-   * targets and makes it easier to inspect the message buffers with a
-   * debugger.
-  size_t buffer[ RTEMS_ZERO_LENGTH_ARRAY ];
-} CORE_message_queue_Buffer;
  *  @brief The possible blocking disciplines for a message queue.
diff --git a/cpukit/include/rtems/score/coremsgbuffer.h b/cpukit/include/rtems/score/coremsgbuffer.h
new file mode 100644
index 0000000000..1960facb34
--- /dev/null
+++ b/cpukit/include/rtems/score/coremsgbuffer.h
@@ -0,0 +1,96 @@
+ * @file
+ * @ingroup RTEMSScoreMessageQueue
+ * @brief This header file defines the buffer data structure used by the
+ *   Message Queue Handler.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 1989, 2009 On-Line Applications Research Corporation (OAR)
+ * are met:
+#ifndef _RTEMS_SCORE_COREMSGBUFFER_H
+#define _RTEMS_SCORE_COREMSGBUFFER_H
+#include <rtems/score/basedefs.h>
+#include <rtems/score/chain.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSScoreMessageQueue
+ * This define enables the support for priority based enqueuing of messages in
+ * the Message Queue Handler.
+#define RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY
+ * @brief The structure is used to organize message buffers of a message queue.
+typedef struct {
+   * @brief This member is used to enqueue the buffer in the pending or free
+   *   buffer queue of a message queue.
+  Chain_Node Node;
+  /** @brief This member defines the size of this message. */
+  size_t size;
+#if defined(RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY)
+  /** @brief This member defines the priority of this message. */
+  int priority;
+#endif
+   * @brief This member contains the actual message.
+   * This is a zero-length array since the maximum message size is defined by
+   * the user.  Use a size_t array to make sure that the member offset is at
+   * the structure end.  This enables a more efficient memcpy() on 64-bit
+   * targets and makes it easier to inspect the message buffers with a
+   * debugger.
+  size_t buffer[ RTEMS_ZERO_LENGTH_ARRAY ];
+} CORE_message_queue_Buffer;
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_COREMSGBUFFER_H */
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index e3606dbdc8..2baf8ef01c 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -337,6 +337,7 @@ install:
   - cpukit/include/rtems/score/corebarrier.h
   - cpukit/include/rtems/score/corebarrierimpl.h
   - cpukit/include/rtems/score/coremsg.h
+  - cpukit/include/rtems/score/coremsgbuffer.h
   - cpukit/include/rtems/score/coremsgimpl.h
   - cpukit/include/rtems/score/coremutex.h
   - cpukit/include/rtems/score/coremuteximpl.h
2.26.2
