[PATCH v2 7/9] rtems: Remove Message_queue_Control::attribute_set
Sebastian Huber
Fri Sep 25 09:51:30 UTC 2020
Add Message_queue_Control::is_global if RTEMS_MULTIPROCESSING is defined. This
reduces the Message_queue_Control size in standard RTEMS configurations.
Update #4007.
cpukit/include/rtems/rtems/messagedata.h | 6 ++++--
cpukit/libmisc/monitor/mon-queue.c | 16 +++++++++++++++-
cpukit/rtems/src/msgqcreate.c | 12 ++++++------
cpukit/rtems/src/msgqdelete.c | 2 +-
4 files changed, 26 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/rtems/messagedata.h b/cpukit/include/rtems/rtems/messagedata.h
index fa1f681473..8c72fba078 100644
--- a/cpukit/include/rtems/rtems/messagedata.h
+++ b/cpukit/include/rtems/rtems/messagedata.h
@@ -40,8 +40,10 @@ typedef struct {
Objects_Control Object;
/** This field is the instance of the SuperCore Message Queue. */
CORE_message_queue_Control message_queue;
- /** This field is the attribute set as defined by the API. */
- rtems_attribute attribute_set;
+#if defined(RTEMS_MULTIPROCESSING)
+ /** This field is true if the message queue is offered globally */
+ bool is_global;
+#endif
} Message_queue_Control;
diff --git a/cpukit/libmisc/monitor/mon-queue.c b/cpukit/libmisc/monitor/mon-queue.c
index 9430797c6c..aadfcd3989 100644
--- a/cpukit/libmisc/monitor/mon-queue.c
+++ b/cpukit/libmisc/monitor/mon-queue.c
@@ -16,7 +16,21 @@ rtems_monitor_queue_canonical(
const Message_queue_Control *rtems_queue = (const Message_queue_Control *) queue_void;
- canonical_queue->attributes = rtems_queue->attribute_set;
+ canonical_queue->attributes = 0;
+ if (
+ rtems_queue->message_queue.operations
+ == &_Thread_queue_Operations_priority
+ canonical_queue->attributes |= RTEMS_PRIORITY;
+ if ( rtems_queue->is_global ) {
+ canonical_queue->attributes |= RTEMS_GLOBAL;
+#endif
canonical_queue->maximum_message_size = rtems_queue->message_queue.maximum_message_size;
canonical_queue->maximum_pending_messages = rtems_queue->message_queue.maximum_pending_messages;
canonical_queue->number_of_pending_messages = rtems_queue->message_queue.number_of_pending_messages;
diff --git a/cpukit/rtems/src/msgqcreate.c b/cpukit/rtems/src/msgqcreate.c
index 79b198199e..20787f00a6 100644
--- a/cpukit/rtems/src/msgqcreate.c
+++ b/cpukit/rtems/src/msgqcreate.c
@@ -53,11 +53,11 @@ rtems_status_code rtems_message_queue_create(
return RTEMS_INVALID_ADDRESS;
- if ( !_System_state_Is_multiprocessing ) {
- attribute_set = _Attributes_Clear( attribute_set, RTEMS_GLOBAL );
+ if ( _System_state_Is_multiprocessing ) {
+ is_global = _Attributes_Is_global( attribute_set );
+ } else {
+ is_global = false;
- is_global = _Attributes_Is_global( attribute_set );
#endif
if ( count == 0 )
@@ -99,9 +99,9 @@ rtems_status_code rtems_message_queue_create(
_Objects_Allocator_unlock();
return RTEMS_TOO_MANY;
-#endif
- the_message_queue->attribute_set = attribute_set;
+ the_message_queue->is_global = is_global;
+#endif
if (_Attributes_Is_priority( attribute_set ) )
discipline = CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY;
diff --git a/cpukit/rtems/src/msgqdelete.c b/cpukit/rtems/src/msgqdelete.c
index 791f96e676..e1d57addc9 100644
--- a/cpukit/rtems/src/msgqdelete.c
+++ b/cpukit/rtems/src/msgqdelete.c
@@ -60,7 +60,7 @@ rtems_status_code rtems_message_queue_delete(
- if ( _Attributes_Is_global( the_message_queue->attribute_set ) ) {
+ if ( the_message_queue->is_global ) {
_Objects_MP_Close(
&_Message_queue_Information,
the_message_queue->Object.id
2.26.2
