[PATCH v2 9/9] validation: Test rtems_message_queue_construct()
Fri Sep 25 09:51:32 UTC 2020
Update #4007.
 .../testsuites/validation/validation-0.yml    |    1 +
 .../validation/tc-message-construct-errors.c  | 1868 +++++++++++++++++
 2 files changed, 1869 insertions(+)
 create mode 100644 testsuites/validation/tc-message-construct-errors.c
diff --git a/spec/build/testsuites/validation/validation-0.yml b/spec/build/testsuites/validation/validation-0.yml
index edc0b570ae..e62e547b95 100644
--- a/spec/build/testsuites/validation/validation-0.yml
+++ b/spec/build/testsuites/validation/validation-0.yml
@@ -11,6 +11,7 @@ includes: []
 ldflags: []
 links: []
 source:
+- testsuites/validation/tc-message-construct-errors.c
 - testsuites/validation/tc-task-construct-errors.c
 - testsuites/validation/ts-validation-0.c
 stlib: []
diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
new file mode 100644
index 0000000000..2dad91dae4
--- /dev/null
+++ b/testsuites/validation/tc-message-construct-errors.c
@@ -0,0 +1,1868 @@
+ * @file
+ * @ingroup RTEMSTestCaseRtemsMessageReqConstructErrors
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * This file was automatically generated.  Do not edit it manually.
+ * Please have a look at
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+ * for information how to maintain and re-generate this file.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <string.h>
+#include <rtems/score/chainimpl.h>
+#include <rtems/score/objectimpl.h>
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseRtemsMessageReqConstructErrors \
+ *   spec:/rtems/message/req/construct-errors
+ * @ingroup RTEMSTestSuiteTestsuitesValidation0
+typedef enum {
+  RtemsMessageReqConstructErrors_Pre_Id_Id,
+  RtemsMessageReqConstructErrors_Pre_Id_Null,
+  RtemsMessageReqConstructErrors_Pre_Id_NA
+} RtemsMessageReqConstructErrors_Pre_Id;
+typedef enum {
+  RtemsMessageReqConstructErrors_Pre_Name_Valid,
+  RtemsMessageReqConstructErrors_Pre_Name_Invalid,
+  RtemsMessageReqConstructErrors_Pre_Name_NA
+} RtemsMessageReqConstructErrors_Pre_Name;
+typedef enum {
+  RtemsMessageReqConstructErrors_Pre_MaxPending_Valid,
+  RtemsMessageReqConstructErrors_Pre_MaxPending_Zero,
+  RtemsMessageReqConstructErrors_Pre_MaxPending_Big,
+  RtemsMessageReqConstructErrors_Pre_MaxPending_NA
+} RtemsMessageReqConstructErrors_Pre_MaxPending;
+typedef enum {
+  RtemsMessageReqConstructErrors_Pre_MaxSize_Valid,
+  RtemsMessageReqConstructErrors_Pre_MaxSize_Zero,
+  RtemsMessageReqConstructErrors_Pre_MaxSize_Big,
+  RtemsMessageReqConstructErrors_Pre_MaxSize_NA
+} RtemsMessageReqConstructErrors_Pre_MaxSize;
+typedef enum {
+  RtemsMessageReqConstructErrors_Pre_Queues_Avail,
+  RtemsMessageReqConstructErrors_Pre_Queues_None,
+  RtemsMessageReqConstructErrors_Pre_Queues_NA
+} RtemsMessageReqConstructErrors_Pre_Queues;
+typedef enum {
+  RtemsMessageReqConstructErrors_Pre_Area_Valid,
+  RtemsMessageReqConstructErrors_Pre_Area_Null,
+  RtemsMessageReqConstructErrors_Pre_Area_NA
+} RtemsMessageReqConstructErrors_Pre_Area;
+typedef enum {
+  RtemsMessageReqConstructErrors_Pre_AreaSize_Valid,
+  RtemsMessageReqConstructErrors_Pre_AreaSize_Invalid,
+  RtemsMessageReqConstructErrors_Pre_AreaSize_NA
+} RtemsMessageReqConstructErrors_Pre_AreaSize;
+typedef enum {
+  RtemsMessageReqConstructErrors_Post_Status_Ok,
+  RtemsMessageReqConstructErrors_Post_Status_InvAddress,
+  RtemsMessageReqConstructErrors_Post_Status_InvName,
+  RtemsMessageReqConstructErrors_Post_Status_InvNumber,
+  RtemsMessageReqConstructErrors_Post_Status_InvSize,
+  RtemsMessageReqConstructErrors_Post_Status_TooMany,
+  RtemsMessageReqConstructErrors_Post_Status_Unsatisfied,
+  RtemsMessageReqConstructErrors_Post_Status_NA
+} RtemsMessageReqConstructErrors_Post_Status;
+ * @brief Test context for spec:/rtems/message/req/construct-errors test case.
+typedef struct {
+  rtems_status_code status;
+  rtems_message_queue_config config;
+  rtems_id *id;
+  rtems_id id_value;
+  Chain_Control message_queues;
+   * @brief This member defines the pre-condition states for the next action.
+  size_t pcs[ 7 ];
+   * @brief This member indicates if the test action loop is currently
+   *   executed.
+  bool in_action_loop;
+} RtemsMessageReqConstructErrors_Context;
+static RtemsMessageReqConstructErrors_Context
+  RtemsMessageReqConstructErrors_Instance;
+static const char * const RtemsMessageReqConstructErrors_PreDesc_Id[] = {
+  "Id",
+  "Null",
+  "NA"
+static const char * const RtemsMessageReqConstructErrors_PreDesc_Name[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const RtemsMessageReqConstructErrors_PreDesc_MaxPending[] = {
+  "Valid",
+  "Zero",
+  "Big",
+  "NA"
+static const char * const RtemsMessageReqConstructErrors_PreDesc_MaxSize[] = {
+  "Valid",
+  "Zero",
+  "Big",
+  "NA"
+static const char * const RtemsMessageReqConstructErrors_PreDesc_Queues[] = {
+  "Avail",
+  "None",
+  "NA"
+static const char * const RtemsMessageReqConstructErrors_PreDesc_Area[] = {
+  "Valid",
+  "Null",
+  "NA"
+static const char * const RtemsMessageReqConstructErrors_PreDesc_AreaSize[] = {
+  "Valid",
+  "Invalid",
+  "NA"
+static const char * const * const RtemsMessageReqConstructErrors_PreDesc[] = {
+  RtemsMessageReqConstructErrors_PreDesc_Id,
+  RtemsMessageReqConstructErrors_PreDesc_Name,
+  RtemsMessageReqConstructErrors_PreDesc_MaxPending,
+  RtemsMessageReqConstructErrors_PreDesc_MaxSize,
+  RtemsMessageReqConstructErrors_PreDesc_Queues,
+  RtemsMessageReqConstructErrors_PreDesc_Area,
+  RtemsMessageReqConstructErrors_PreDesc_AreaSize,
+  NULL
+#define MAX_MESSAGE_QUEUES 4
+#define MAX_PENDING_MESSAGES 1
+#define MAX_MESSAGE_SIZE 1
+static RTEMS_MESSAGE_QUEUE_BUFFER( MAX_MESSAGE_SIZE )
+  exhaust_buffers[ MAX_MESSAGE_QUEUES ][ MAX_PENDING_MESSAGES ];
+  buffers[ MAX_PENDING_MESSAGES ];
+static void RtemsMessageReqConstructErrors_Pre_Id_Prepare(
+  RtemsMessageReqConstructErrors_Context *ctx,
+  RtemsMessageReqConstructErrors_Pre_Id   state
+  switch ( state ) {
+    case RtemsMessageReqConstructErrors_Pre_Id_Id: {
+      ctx->id = &ctx->id_value;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_Id_Null: {
+      ctx->id = NULL;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_Id_NA:
+      break;
+static void RtemsMessageReqConstructErrors_Pre_Name_Prepare(
+  RtemsMessageReqConstructErrors_Pre_Name state
+    case RtemsMessageReqConstructErrors_Pre_Name_Valid: {
+      ctx->config.name = rtems_build_name( 'N', 'A', 'M', 'E' );
+      break;
+    case RtemsMessageReqConstructErrors_Pre_Name_Invalid: {
+      ctx->config.name = 0;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_Name_NA:
+      break;
+static void RtemsMessageReqConstructErrors_Pre_MaxPending_Prepare(
+  RtemsMessageReqConstructErrors_Pre_MaxPending state
+    case RtemsMessageReqConstructErrors_Pre_MaxPending_Valid: {
+      ctx->config.maximum_pending_messages = MAX_PENDING_MESSAGES;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_MaxPending_Zero: {
+      ctx->config.maximum_pending_messages = 0;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_MaxPending_Big: {
+      ctx->config.maximum_pending_messages = UINT32_MAX;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_MaxPending_NA:
+      break;
+static void RtemsMessageReqConstructErrors_Pre_MaxSize_Prepare(
+  RtemsMessageReqConstructErrors_Pre_MaxSize state
+    case RtemsMessageReqConstructErrors_Pre_MaxSize_Valid: {
+      ctx->config.maximum_message_size = MAX_MESSAGE_SIZE;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_MaxSize_Zero: {
+      ctx->config.maximum_message_size = 0;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_MaxSize_Big: {
+      ctx->config.maximum_message_size = SIZE_MAX;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_MaxSize_NA:
+      break;
+static void RtemsMessageReqConstructErrors_Pre_Queues_Prepare(
+  RtemsMessageReqConstructErrors_Pre_Queues state
+  size_t                     i;
+    case RtemsMessageReqConstructErrors_Pre_Queues_Avail: {
+      /* Nothing to do */
+      break;
+    case RtemsMessageReqConstructErrors_Pre_Queues_None: {
+      memset( &config, 0, sizeof( config ) );
+      config.name = rtems_build_name( 'M', 'S', 'G', 'Q' );
+      config.maximum_pending_messages = MAX_PENDING_MESSAGES;
+      config.maximum_message_size = MAX_MESSAGE_SIZE;
+      config.storage_size = sizeof( exhaust_buffers[ 0 ] );
+      config.attributes = RTEMS_DEFAULT_ATTRIBUTES;
+      i = 0;
+      while ( i < MAX_MESSAGE_QUEUES ) {
+        rtems_status_code sc;
+        rtems_id          id;
+        config.storage_area = exhaust_buffers[ i ];
+        sc = rtems_message_queue_construct( &config, &id );
+        if ( sc == RTEMS_SUCCESSFUL ) {
+          Objects_Control           *obj;
+          const Objects_Information *info;
+          info = _Objects_Get_information_id( id );
+          T_quiet_assert_not_null( info );
+          obj = _Objects_Get_no_protection( id, info );
+          T_quiet_assert_not_null( obj );
+          _Chain_Append_unprotected( &ctx->message_queues, &obj->Node );
+        } else {
+          T_quiet_rsc( sc, RTEMS_TOO_MANY );
+          break;
+        ++i;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_Queues_NA:
+      break;
+static void RtemsMessageReqConstructErrors_Pre_Area_Prepare(
+  RtemsMessageReqConstructErrors_Pre_Area state
+    case RtemsMessageReqConstructErrors_Pre_Area_Valid: {
+      ctx->config.storage_area = buffers;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_Area_Null: {
+      ctx->config.storage_area = NULL;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_Area_NA:
+      break;
+static void RtemsMessageReqConstructErrors_Pre_AreaSize_Prepare(
+  RtemsMessageReqConstructErrors_Pre_AreaSize state
+    case RtemsMessageReqConstructErrors_Pre_AreaSize_Valid: {
+      ctx->config.storage_size = sizeof( buffers );
+      break;
+    case RtemsMessageReqConstructErrors_Pre_AreaSize_Invalid: {
+      ctx->config.storage_size = SIZE_MAX;
+      break;
+    case RtemsMessageReqConstructErrors_Pre_AreaSize_NA:
+      break;
+static void RtemsMessageReqConstructErrors_Post_Status_Check(
+  RtemsMessageReqConstructErrors_Post_Status state
+    case RtemsMessageReqConstructErrors_Post_Status_Ok: {
+      T_rsc_success( ctx->status );
+      T_eq_ptr( ctx->id, &ctx->id_value );
+      T_ne_u32( ctx->id_value, 0xffffffff );
+      sc = rtems_message_queue_delete( ctx->id_value );
+      T_rsc_success( sc );
+      break;
+    case RtemsMessageReqConstructErrors_Post_Status_InvAddress: {
+      T_rsc( ctx->status, RTEMS_INVALID_ADDRESS );
+      T_null( ctx->id );
+      T_eq_u32( ctx->id_value, 0xffffffff );
+      break;
+    case RtemsMessageReqConstructErrors_Post_Status_InvName: {
+      T_rsc( ctx->status, RTEMS_INVALID_NAME );
+      break;
+    case RtemsMessageReqConstructErrors_Post_Status_InvNumber: {
+      T_rsc( ctx->status, RTEMS_INVALID_NUMBER );
+      break;
+    case RtemsMessageReqConstructErrors_Post_Status_InvSize: {
+      T_rsc( ctx->status, RTEMS_INVALID_SIZE );
+      break;
+    case RtemsMessageReqConstructErrors_Post_Status_TooMany: {
+      T_rsc( ctx->status, RTEMS_TOO_MANY );
+      break;
+    case RtemsMessageReqConstructErrors_Post_Status_Unsatisfied: {
+      T_rsc( ctx->status, RTEMS_UNSATISFIED  );
+      break;
+    case RtemsMessageReqConstructErrors_Post_Status_NA:
+      break;
+static void RtemsMessageReqConstructErrors_Setup(
+  _Chain_Initialize_empty( &ctx->message_queues );
+static void RtemsMessageReqConstructErrors_Setup_Wrap( void *arg )
+  RtemsMessageReqConstructErrors_Context *ctx;
+  ctx = arg;
+  ctx->in_action_loop = false;
+  RtemsMessageReqConstructErrors_Setup( ctx );
+static size_t RtemsMessageReqConstructErrors_Scope(
+  void  *arg,
+  char  *buf,
+  size_t n
+  ctx = arg;
+  if ( ctx->in_action_loop ) {
+    return T_get_scope(
+      RtemsMessageReqConstructErrors_PreDesc,
+      buf,
+      n,
+      ctx->pcs
+  return 0;
+static T_fixture RtemsMessageReqConstructErrors_Fixture = {
+  .setup = RtemsMessageReqConstructErrors_Setup_Wrap,
+  .stop = NULL,
+  .teardown = NULL,
+  .scope = RtemsMessageReqConstructErrors_Scope,
+  .initial_context = &RtemsMessageReqConstructErrors_Instance
+static const uint8_t RtemsMessageReqConstructErrors_TransitionMap[][ 1 ] = {
+static const struct {
+  uint8_t Skip : 1;
+  uint8_t Pre_Id_NA : 1;
+  uint8_t Pre_Name_NA : 1;
+  uint8_t Pre_MaxPending_NA : 1;
+  uint8_t Pre_MaxSize_NA : 1;
+  uint8_t Pre_Queues_NA : 1;
+  uint8_t Pre_Area_NA : 1;
+  uint8_t Pre_AreaSize_NA : 1;
+} RtemsMessageReqConstructErrors_TransitionInfo[] = {
+    0, 0, 0, 0, 0, 0, 0, 0
+static void RtemsMessageReqConstructErrors_Prepare(
+  ctx->id_value = 0xffffffff;
+  memset( &ctx->config, 0, sizeof( ctx->config ) );
+static void RtemsMessageReqConstructErrors_Action(
+  ctx->status = rtems_message_queue_construct( &ctx->config, ctx->id );
+static void RtemsMessageReqConstructErrors_Cleanup(
+  Chain_Node *node;
+  while ( ( node = _Chain_Get_unprotected( &ctx->message_queues ) ) ) {
+    obj = (Objects_Control *) node;
+    sc = rtems_message_queue_delete( obj->id );
+    T_quiet_rsc_success( sc );
+ * @fn void T_case_body_RtemsMessageReqConstructErrors( void )
+T_TEST_CASE_FIXTURE(
+  RtemsMessageReqConstructErrors,
+  &RtemsMessageReqConstructErrors_Fixture
+  size_t index;
+  ctx = T_fixture_context();
+  ctx->in_action_loop = true;
+  index = 0;
+  for (
+    ctx->pcs[ 0 ] = RtemsMessageReqConstructErrors_Pre_Id_Id;
+    ctx->pcs[ 0 ] < RtemsMessageReqConstructErrors_Pre_Id_NA;
+    ++ctx->pcs[ 0 ]
+    if ( RtemsMessageReqConstructErrors_TransitionInfo[ index ].Pre_Id_NA ) {
+      ctx->pcs[ 0 ] = RtemsMessageReqConstructErrors_Pre_Id_NA;
+      index += ( RtemsMessageReqConstructErrors_Pre_Id_NA - 1 )
+        * RtemsMessageReqConstructErrors_Pre_Name_NA
+        * RtemsMessageReqConstructErrors_Pre_MaxPending_NA
+        * RtemsMessageReqConstructErrors_Pre_MaxSize_NA
+        * RtemsMessageReqConstructErrors_Pre_Queues_NA
+        * RtemsMessageReqConstructErrors_Pre_Area_NA
+        * RtemsMessageReqConstructErrors_Pre_AreaSize_NA;
+    for (
+      ctx->pcs[ 1 ] = RtemsMessageReqConstructErrors_Pre_Name_Valid;
+      ctx->pcs[ 1 ] < RtemsMessageReqConstructErrors_Pre_Name_NA;
+      ++ctx->pcs[ 1 ]
+      if ( RtemsMessageReqConstructErrors_TransitionInfo[ index ].Pre_Name_NA ) {
+        ctx->pcs[ 1 ] = RtemsMessageReqConstructErrors_Pre_Name_NA;
+        index += ( RtemsMessageReqConstructErrors_Pre_Name_NA - 1 )
+      for (
+        ctx->pcs[ 2 ] = RtemsMessageReqConstructErrors_Pre_MaxPending_Valid;
+        ctx->pcs[ 2 ] < RtemsMessageReqConstructErrors_Pre_MaxPending_NA;
+        ++ctx->pcs[ 2 ]
+        if ( RtemsMessageReqConstructErrors_TransitionInfo[ index ].Pre_MaxPending_NA ) {
+          ctx->pcs[ 2 ] = RtemsMessageReqConstructErrors_Pre_MaxPending_NA;
+          index += ( RtemsMessageReqConstructErrors_Pre_MaxPending_NA - 1 )
+        for (
+          ctx->pcs[ 3 ] = RtemsMessageReqConstructErrors_Pre_MaxSize_Valid;
+          ctx->pcs[ 3 ] < RtemsMessageReqConstructErrors_Pre_MaxSize_NA;
+          ++ctx->pcs[ 3 ]
+          if ( RtemsMessageReqConstructErrors_TransitionInfo[ index ].Pre_MaxSize_NA ) {
+            ctx->pcs[ 3 ] = RtemsMessageReqConstructErrors_Pre_MaxSize_NA;
+            index += ( RtemsMessageReqConstructErrors_Pre_MaxSize_NA - 1 )
+          for (
+            ctx->pcs[ 4 ] = RtemsMessageReqConstructErrors_Pre_Queues_Avail;
+            ctx->pcs[ 4 ] < RtemsMessageReqConstructErrors_Pre_Queues_NA;
+            ++ctx->pcs[ 4 ]
+            if ( RtemsMessageReqConstructErrors_TransitionInfo[ index ].Pre_Queues_NA ) {
+              ctx->pcs[ 4 ] = RtemsMessageReqConstructErrors_Pre_Queues_NA;
+              index += ( RtemsMessageReqConstructErrors_Pre_Queues_NA - 1 )
+            for (
+              ctx->pcs[ 5 ] = RtemsMessageReqConstructErrors_Pre_Area_Valid;
+              ctx->pcs[ 5 ] < RtemsMessageReqConstructErrors_Pre_Area_NA;
+              ++ctx->pcs[ 5 ]
+              if ( RtemsMessageReqConstructErrors_TransitionInfo[ index ].Pre_Area_NA ) {
+                ctx->pcs[ 5 ] = RtemsMessageReqConstructErrors_Pre_Area_NA;
+                index += ( RtemsMessageReqConstructErrors_Pre_Area_NA - 1 )
+              for (
+                ctx->pcs[ 6 ] = RtemsMessageReqConstructErrors_Pre_AreaSize_Valid;
+                ctx->pcs[ 6 ] < RtemsMessageReqConstructErrors_Pre_AreaSize_NA;
+                ++ctx->pcs[ 6 ]
+                if ( RtemsMessageReqConstructErrors_TransitionInfo[ index ].Pre_AreaSize_NA ) {
+                  ctx->pcs[ 6 ] = RtemsMessageReqConstructErrors_Pre_AreaSize_NA;
+                  index += ( RtemsMessageReqConstructErrors_Pre_AreaSize_NA - 1 );
+                if ( RtemsMessageReqConstructErrors_TransitionInfo[ index ].Skip ) {
+                  ++index;
+                  continue;
+                RtemsMessageReqConstructErrors_Prepare( ctx );
+                RtemsMessageReqConstructErrors_Pre_Id_Prepare(
+                  ctx,
+                  ctx->pcs[ 0 ]
+                RtemsMessageReqConstructErrors_Pre_Name_Prepare(
+                  ctx,
+                  ctx->pcs[ 1 ]
+                RtemsMessageReqConstructErrors_Pre_MaxPending_Prepare(
+                  ctx,
+                  ctx->pcs[ 2 ]
+                RtemsMessageReqConstructErrors_Pre_MaxSize_Prepare(
+                  ctx,
+                  ctx->pcs[ 3 ]
+                RtemsMessageReqConstructErrors_Pre_Queues_Prepare(
+                  ctx,
+                  ctx->pcs[ 4 ]
+                RtemsMessageReqConstructErrors_Pre_Area_Prepare(
+                  ctx,
+                  ctx->pcs[ 5 ]
+                RtemsMessageReqConstructErrors_Pre_AreaSize_Prepare(
+                  ctx,
+                  ctx->pcs[ 6 ]
+                RtemsMessageReqConstructErrors_Action( ctx );
+                RtemsMessageReqConstructErrors_Post_Status_Check(
+                  ctx,
+                  RtemsMessageReqConstructErrors_TransitionMap[ index ][ 0 ]
+                RtemsMessageReqConstructErrors_Cleanup( ctx );
+                ++index;
2.26.2
